Steering wheel vibration 45-60mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BluntTaco, Aug 29, 2016.
  1. Aug 29, 2016 at 6:00 PM
    BluntTaco
    BluntTaco [OP] Tight and Right
    Randy
    Centreville, MD
    09' Taco 4x4 TRD Sport
    Undercover, Pioneer AVIC Z130BT, Toyota Roof Rack, Drop in aFe. Camburg UCA's, Toytec Ultimate 5100 Kit, OME Dakar Rear Kit, Custom Mayhem Grill, Wicked Muff w/tip, Some Debadging.
    I have an issue I need help nailing down the cause.
    I have a bad drivers side bearing and possibly the passenger going as well. With that said I have an issue I believe to be non related but I could be wrong. I plan on replacing both bearings next weekend when the parts come in.
    At speeds above 45 with vibration getting worse into 55-60 the steering wheel can move 1-2 inches in vibration/wobble call it what you will. It almost feels like one of my or several of my tires are not round. Imbalanced tires? Alignment?
    If I look at the bed of my pickup you can see it moving up and down as well. I have checked all the bolts on the bed it's snug.
    Do you think this is from the bearings?
  2. Aug 29, 2016 at 6:26 PM
    Majoryucknuts
    Majoryucknuts Active Member
    AZ
    07 White Taco TRD Sport 4WD Double Cab
    ARB Air Lockers Camburg UCAs King Coilovers Deever Leaf Springs
    I had this issue a few months back and could really feel it from the front end on the freeway. I did the bearings first since they were making noise at high speeds, this helped a bit but didn't fix it. I talked to a jeep buddy of mine who said to check the tie rods, I watched a few YouTube videos on how to check them and found quite a bit of play in them. Dealer wanted $250+ for each side, I bought the parts om Amazon for about $40 each and replaced them in an afternoon. Followed up with alignment and wheel balance, problem solved. Still get a slight shake but it's most likely the over sized tires. Check your tie rods, and good luck!
    BluntTaco[OP] likes this.
  3. Aug 29, 2016 at 6:41 PM
    BluntTaco
    Randy
    Centreville, MD
    Major did you have a constant vibe once it started, with mine it will start go away and then start back up randomly.
  4. Aug 29, 2016 at 6:46 PM
    badmotorfinger
    badmotorfinger Active Member
    2007 Indigo Ink DCLB SR5
    Billy 5100s on all 4 corners + bags in the back.
    Mine does this as well. I've replaced the bearings in the front on both sides, new springs and shocks, steering rack bushings, and countless RF balances and alignments... still shakes.
    I've come to accept the fact that it's by design for these trucks.
    10trdtaco likes this.
  5. Aug 29, 2016 at 6:51 PM
    Majoryucknuts
    AZ
    Mine seemed to be related to my speed, it would start up between 45-60 mph then it wold smooth out come back around 75-80 mph. If it is the bearings you can definitely hear them, sounds like a loud drone coming from the front end.
  6. Aug 29, 2016 at 7:33 PM
    BluntTaco
    Randy
    Centreville, MD
    Ok sounds like could be both for me, the front left has play when checked at 6 &12 . I'll check the tie rods tomorrow. Thanks
    Majoryucknuts[QUOTED] likes this.
  7. Aug 29, 2016 at 8:04 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    OEM Hub-centric Wheels? Get them balanced and make sure they use the Haweka Adapter. If they don't know or have one take it some place else that does use it.
    If after market wheels make sure they are Hub Centric. If they are not get the proper hub adapter rings.
    Majoryucknuts likes this.
  8. Aug 29, 2016 at 8:47 PM
    Majoryucknuts
    AZ
    This is interesting, had no idea this could be an issue. I'll have to check my wheels.
  9. Aug 29, 2016 at 10:04 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    This has been an issue with Toyota's for as long as I can remember...
  10. Aug 30, 2016 at 4:03 AM
    BluntTaco
    Randy
    Centreville, MD
    Thanks I'll check this as well
  11. Aug 30, 2016 at 2:24 PM
    BluntTaco
    Randy
    Centreville, MD
    Tie rods seem good. Need to check the balance now.
  12. Aug 30, 2016 at 2:34 PM
    Majoryucknuts
    AZ
    That's good.
    I ordered some hub centric rings. I'll let you know how it goes.
  13. Aug 30, 2016 at 2:55 PM
    BluntTaco
    Randy
    Centreville, MD
    Spacers?
  14. Aug 30, 2016 at 4:19 PM
    Majoryucknuts
    AZ
    https://youtu.be/D3dl3XTl3FY
    They appear to help center your wheel on the hub from the center instead of from the lugs.
  15. Aug 30, 2016 at 4:57 PM
    BluntTaco
    Randy
    Centreville, MD
    Ah I see, I'm still running stock wheels.
  16. Aug 30, 2016 at 5:30 PM
    Majoryucknuts
    AZ
    Oh, you shouldn't have that much vibration I wouldn't think unless there was indeed an issue. So I think you're on the right path with checking parts and balancing.
  17. Sep 23, 2016 at 4:33 AM
    BluntTaco
    Randy
    Centreville, MD
    Update:
    I replaced my drivers side hub/bearing. Pretty much fixed all the vibration. I still plan on another balance and alignment check. The bearing didn't have much play at all when jacked up but it sounded like a pepper grinder when I spun the wheel.
