Steering wheel vibration after modifications
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PBDaddy, May 11, 2023.
  1. May 11, 2023 at 8:26 AM
    PBDaddy
    PBDaddy [OP] Member
    2023 SR 4x4 Double Cab
    Icon Alloys Alpha 17 x 8.5 265/70/17 Falken Wildpeaks Rough Country Retract Steps Tint DIY Grill Mod
    Right to the point…..
    - Purchased new in January
    - Noticed shortly after (prior to mods) that there was a steering wheel vibration as the truck was shifting or at the beginning of “pull”. Called dealer and they said just wait to 5k service.
    - The vibration is more like a phone set to vibrate feel, although not that aggressive. The vibration is more pronounced on top of the steering wheel.
    -Not a shake or wobble.
    - if anything, it has gotten worse not better.
    - Truck has aftermarket wheels and tires that are properly balanced.
    - Perfect alignment
    - 2” front spacer lift, 1” rear block lift
    Respectfully, I am not looking for opinions. I am hoping that someone has encountered this issue and found a fix.
    Thanks!
  2. May 11, 2023 at 8:30 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Did you buy the truck with aftermarket lift, rims and tires?
  3. May 11, 2023 at 8:33 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Well the only thing that is different about your truck than the others is:
    Aftermarket wheels and tires.
    Lifted.
    Done by the dealer?
    So take it back to stock and see if it still happens.
    Nellie326 and Junkhead like this.
  4. May 11, 2023 at 8:38 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Probably don't need to yell "HELP!!!" in your thread title. You aren't stuck in the desert
    fmb, 3GTCMLMTD, typhoonegator and 2 others like this.
  5. May 11, 2023 at 8:56 AM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    "Respectfully" if you're not looking for opinions, don't ask people to diagnose your vehicle on the internet. No one can state factually what your problem is...you'll need a therapist for that. :rimshot:
    HisDad, 3GTCMLMTD, hiPSI and 3 others like this.
  6. May 11, 2023 at 9:45 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    so many people get hurt feelings nowadays
    BSFord and Chew like this.
  7. May 11, 2023 at 12:32 PM
    PBDaddy
    PBDaddy [OP] Member
    No I installed. Bought truck new
  8. May 11, 2023 at 12:40 PM
    PBDaddy
    PBDaddy [OP] Member
    Problem was observed prior to lift.
    Reason I stated not looking for opinions is to not take the forum down a rabbit hole.
    Trying to keep focused on the real issue and hopefully share information instead of making a post 15 pages with no resolution
  9. May 11, 2023 at 12:57 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Modifying something that has bearing issues with a 2 in lift is not wise. People tell you the needle bearings are prone to failure on any lift and advise buying new bearing for the lift even if it was was running well before.
    I would start with those bearings, if not reverting to pre-lift just to make things stable first.
    PBDaddy[QUOTED][OP] likes this.
  10. May 11, 2023 at 3:45 PM
    PBDaddy
    PBDaddy [OP] Member
    Thanks for the diagnosis. I scheduled a therapy appointment
  11. May 11, 2023 at 5:12 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    You bought a new truck. You have a warranty. Take it to the dealer for repair. Don’t ask them and don’t accept “wait for the 5K service”.
    PBDaddy[OP] likes this.
  12. May 11, 2023 at 5:50 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    I had some steering wheel shake at around 60mph after I replaced wheels tires. Took it back to my alignment guy turns out I threw a wheel weight. they replaced the weight while rebalancing the tire/wheel problem solved.
    SR-71A likes this.
  13. May 12, 2023 at 4:40 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Sounds like the same stupid thing a buddy did on his 2019 v6 tacoma. Never really drove the truck when it was stock...he had to do a 3'' lift with 33' big ass mud tires to look the cool part. He never had any intention of using the truck off road, but did end up with a truck that performed like chit with all kinds of vibrations. At any rate he put the truck back to stock, but it still wasn't to his liking, so he traded it for a new frontier...now he's happy. End of story.
  14. May 12, 2023 at 4:51 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Do you feel the vibration through the floorboard? If so, that was my experience with both a failing needle bearing, and later a drivers side front wheel bearing that was failing due to a missing seal and resulting corrosion.
  15. May 12, 2023 at 3:37 PM
    PBDaddy
    PBDaddy [OP] Member
    Update:
    As mentioned in this thread and the thread @Ryan188 mentioned, engaged 4wd and the vibration pretty much disappeared.
    Sounds like the stock needle bearing is crap and is hit or miss even on stock tacomas which explains why I felt it before mods. Mods are minimal, 2/1 lift and 265 tires.
    Gonna order ECGS components like suggested in the thread Ryan shared
    Hook78 and Ryan188 like this.
