Steering Wheel Vibration After New Tires (Suggestions)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pta_taco, Mar 12, 2018.
  1. Mar 12, 2018 at 1:41 PM
    #41
    Fortunt1
    Fortunt1 Well-Known Member
    Thomas
    Iowa
    16' SRT Charger...purple
    And btw, I tried all the stuff I grand and nothing made it change. It’s the tires.
  2. Mar 12, 2018 at 1:44 PM
    #42
    Zacowacko
    Zacowacko Well-Known Member
    Zack
    SW, OK
    2013 DCSB TE 4x4 6spd
    TRD Pro Susp., Icon AAL, Bags w/cradles, US OR Bumper w/Smitty, 2Lo Mod
    He's lifted, your not.
  3. Mar 12, 2018 at 1:49 PM
    #43
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    Actually... You can tell if it is the needle bearing by shifting into 4Hi. If the vibe goes away it is the needle bearing. If the vibe continues while in 4Hi then it is something else.
  4. Mar 12, 2018 at 2:52 PM
    #44
    ReloadX
    ReloadX Well-Known Member
    I believe its the tires that are causing the vibration. Did you try putting your stock wheels back on to see if you still have the vibrations?
  5. Mar 12, 2018 at 2:55 PM
    #45
    pta_taco
    pta_taco [OP] Exploring when I can
    Patrick
    Greenville, South Carolina
    2016 TRD Off-Road
    https://www.tacomaworld.com/threads/pta_taco-2016-offroad-build.493686/
    no i sold the ko2, wishing i still had them to test but i cant now
  6. Mar 12, 2018 at 3:08 PM
    #46
    Fortunt1
    Thomas
    Iowa
    Take it to the dealership. They’ll swap a set out and drive it
  7. Mar 12, 2018 at 4:02 PM
    #47
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    my bet is needle bearing, i would try 4hi first to see if that eliminates it
  8. Mar 13, 2018 at 8:11 AM
    #48
    pta_taco
    Patrick
    2016 TRD Off-Road
    alright so i got the vibration going this morning because of the cold and every time i put in into 4h it went right away and everytime i took it out the vibration came back about 100 feet later. (repeated about 4 times ) gonna take a guess that the cold tires provoke the vibration even more in the morning.
  9. Mar 13, 2018 at 8:41 AM
    #49
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    Strongly suggests needle bearing is the culprit. I'd look into replacing it with ECGS bushing.
  10. Mar 13, 2018 at 8:47 AM
    #50
    pta_taco
    Patrick
    2016 TRD Off-Road
    is it a easy do it yourself, i know how to the basics like brake change and suspension.. or better off at a shop?
  11. Mar 13, 2018 at 8:50 AM
    #51
    Beer:30
    Kevin
    2016 DCSB OR V6 4X4
  12. Mar 13, 2018 at 8:53 AM
    #52
    pta_taco
    Patrick
    2016 TRD Off-Road
  13. Mar 13, 2018 at 8:55 AM
    #53
    Beer:30
    Kevin
    2016 DCSB OR V6 4X4
    Yes, drivers side only.
  14. Mar 13, 2018 at 9:00 AM
    #54
    upTOPOverland_Drew
    Drew
    Littleton, CO
    You got this OP
  15. Mar 13, 2018 at 10:49 AM
    #55
    Fortunt1
    Thomas
    Iowa
    I wish that’s what mine was :anonymous:
    pta_taco[OP] likes this.
  16. Mar 13, 2018 at 12:08 PM
    #56
    Zacowacko
    Zack
    SW, OK
    Or go get the replacement TSB bearing under 60k warranty, if your not there yet. I have 18 months and 45k on mine. Not a peep since.
  17. Mar 13, 2018 at 2:30 PM
    #57
    pta_taco
    Patrick
    2016 TRD Off-Road
    Yea I’m at 22k with an extended warranty But my local dealship isn’t very helpful. So I’ll try but if I ended up to the ecgs in the long run I might as well not deal with Toyota?
  18. Mar 14, 2018 at 10:26 AM
    #58
    Zacowacko
    Zack
    SW, OK
    Ya, mine didn't even give a damn that i lifted it. Its such a well known problem, they started putting them in the new diffs. Some of the dealerships replace the whole diff, as its already in the new ones.
  19. Apr 9, 2018 at 5:29 PM
    #59
    Madtown
    Madtown Well-Known Member
    Eric
    Madison,WI
    Former 3G Tacoma owner
    Currently dealing with this issue as well with Falken Wildpeaks. Shimmy in steering wheel 40mph & above. Roadforce balanced twice & all 20 pounds or under. Really frustrated. Stock suspension. Going to test the needle bearing tomorrow. OP did you ever figure your truck out?
  20. Apr 9, 2018 at 5:35 PM
    #60
    pta_taco
    Patrick
    2016 TRD Off-Road
    Yes. Tired everything. Even warranted tires but still getting the random vibration. Sometime in the steering wheel some times in the gas pedal. Then started this thread. Tried the 4 wheel drive method and went away every time so I looked into the needle bearing and Toyota confirmed it was the problem. Still haven’t not replaced it so can’t say 100% sure but I’m 99% sure.
