Steering wheel vibration at 25mph
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kyron4, Dec 23, 2018.
  1. Dec 23, 2018 at 4:34 AM
    Kyron4
    Kyron4 [OP] Member
    Kyron
    2018 trd off road Tacoma
    Hi!!
    I have a 2018 Tacoma trd off road with a leveling kit ( 3in in the front and 2 in the rear). I have done loads of research on how to get rid of the vibration after the lift and can’t seem to eliminate it. It is driving me crazy and I need help! I have done the driveline drop kit( old man emu). As well as the infamous ecgs bushing install by a reputable shop. As well as multiple alignments. None of this has fixed it and it happens at exactly 20-25 mph and in any other speed range is perfectly smooth. Any suggestions would be greatly appreciated thank you !
  2. Dec 23, 2018 at 4:55 AM
    beergeek
    beergeek Well-Known Member
    RI
    2017 Black Tacoma Limited
    Can’t help you with your issue, but the ECGS bushing is the exact opposite of “infamous”.
    SpeySquatch likes this.
  3. Dec 23, 2018 at 4:58 AM
    Clearwater Bill
    Billy
    Largo Florida
    You don't mention any tire balancing exercises.
    Steering wheel is front tire. Rotate them to the rear and see if the vibration moves to your seat.
    You could have a flawed tire as well, which could be warrantied if it meets the rules for such.
    beergeek likes this.
  4. Dec 23, 2018 at 7:53 AM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    A 2/3 is not leveling its a lift. As for vibration, you have ko2s by any chance? Like Bill said, balancing first (road force balanced) if that doesn't solve it then ecgs bearing install is probably a good idea.
  5. Dec 23, 2018 at 7:59 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    He stated he did the ECGS bushing already. I say a shim for a 2 inch rear block.
  6. Dec 23, 2018 at 8:55 PM
    Kyron4
    Kyron4 [OP] Member
    Kyron
    I do not have ko2’s on my vehicle. Stock 2018 tires and wheels. I will try switching the front tires to the rear and see if that has any affect thank you for the suggestions! This is bothering me so much I got to figure it out.
  7. Dec 23, 2018 at 9:07 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Thank god its kyron4. Kyron5 is the WORST. Not kidding either.
    ALI3N_123, Hank Heel and Kyron4[OP] like this.
  8. Dec 23, 2018 at 9:15 PM
    Trouble_The_Tacoma
    Trouble_The_Tacoma Well-Known Member
    Conrad
    Rotate and balance. Then alignment.
  9. Dec 23, 2018 at 9:32 PM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    Have you checked the drive shaft to pinion gear angles? A 2" back calls for a angle wedge.
    VaToy likes this.
  10. Dec 24, 2018 at 12:30 AM
    VaToy
    Parts Unknown
    If it's stock wheels and tires and it did it after lift installed, sounds like the lift caused it.
  11. Dec 24, 2018 at 2:11 AM
    Tacoknife
    Tacoknife Well-Known Member
    Stephen
    WV
    2018 Tacoma Sport 4DLB 4x4
    DBcustomzfab Grill
    Maybe check and recheck all the tightness/torque specs of all your bolts that where involved with your lift kit? And this might sound dumb but is it possible the 2” lift in the rear was installed backwards? Possibly there already shimmed and where installed the wrong way!
  12. Dec 24, 2018 at 2:49 AM
    Kyron4
    Kyron4 [OP] Member
    Kyron
    The vibration in the steering wheel was non existent until the lift was added.
  13. Dec 24, 2018 at 4:58 AM
    VaToy
    Parts Unknown
    I understand that you did a diff drop but was that front and rear? If not looks a front diff drop, but I'm betting on a shim. Are your rear blocks tappered?
  14. Jan 5, 2019 at 4:18 PM
    Kyron4
    Kyron4 [OP] Member
    Kyron
    Wheels and tires balanced and rotated today. Helped the shaking slightly but it is still pretty rough. Any other ideas would be greatly appreciated before I go to Toyota next weekend
  15. Jan 5, 2019 at 4:24 PM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    Did you determine if it disappears in four wheel drive? What kind of lift did you install?
  16. Jan 5, 2019 at 4:29 PM
    Kyron4
    Kyron4 [OP] Member
    Kyron
    Yes it is still present in 4wd. It was a “ rough country leveling kit”
  17. Jan 5, 2019 at 4:36 PM
    Troyken
    NY
    Does it change at all if you shift to neutral at that speed range? I'm wondering about the rear drive shaft/ u-joints. If four wheel drive doesn't change it that may eliminate front cvs/ axels. I have noticed rear u joint problems vibrating the rear view mirror too.
  18. Jan 5, 2019 at 4:38 PM
    Kyron4
    Kyron4 [OP] Member
    Kyron
    Yes the vibration is still there when in neutral at all times.
  19. Jan 5, 2019 at 4:38 PM
    VaToy
    Parts Unknown
    Did you do a front diff drop?
  20. Jan 5, 2019 at 4:39 PM
    Kyron4
    Kyron4 [OP] Member
    Kyron
    No. I have heard a lot of mixed opinions on that. Do you think I should install that before taking the vehicle to the dealership and have them check it out?
