Steering wheel vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bradahboy808, Aug 4, 2021.
  1. Aug 4, 2021 at 12:14 AM
    Bradahboy808
    Bradahboy808 [OP] Member
    Koby
    Kauai as why
    2006 tacoma access cab 6speed
    3 in level kit, procomp wheels and all terrains (265/75/17)
    Howzit going guys. I got a steering wheel shake at around 45 miles per hour. I just had the wheel bearing changed as well as the inner and outer tie rods about 3 months ago which did not solve the issue. I brought it to an alignment shop today and they informed me that there was play in the wheel on the drivers side and said that I would have to replace both the wheel bearings and tie rods which I think might be the generic answer they tell everybody.
    Also when I turn my steering wheel all the way from a dead stop, it sometimes makes a popping sound on the drivers side.
    I was wondering if anybody knows about an underlying issue with these trucks that would cause play in the wheels other than the wheel bearing and tie rods? Any help is much appreciated.
  2. Aug 4, 2021 at 1:09 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The obvious thing to check would be tire balance?
    Has this been done?
    How are the ball joints?
    Ball joints can cause play in the wheel and a popping sound.
    As well as the worn or loose control arm bushings.
  3. Aug 4, 2021 at 1:18 AM
    wiggler
    wiggler Well-Known Member
    HILO
    2013 OR AC 6MT & 1998 4Runner sr5 auto
    My friends 2017(I think) TRD pro:
    https://youtu.be/6lUgJnb_epA
    The culprit ended up being the brake rotors, surprisingly enough.
    Could also check the steering rack bushings? Heard that can be a problem also. Energy Suspension sells a poly bushing set for about $50.
    Also, could just be shitty roads on Oahu? Lol. But serious, it’ probably the rotors, or as others said tire balance. If not I’d look into the steering rack bushings. Just do a search here. Or as said above, tie rods, LCA bushings, etc.. really could be any suspension or steering component going bad. Even just your shocks being totally shot to shit will make the truck do some weird shit. Shoots brah
  4. Aug 4, 2021 at 9:50 AM
    Itsnickfool
    Itsnickfool Active Member
    Nick
    Long beach
    07tacoma
    Suspension,wheels, lighting, bumpers
    Don’t know if you’re 4wd but could be a cv issue also.
  5. Aug 4, 2021 at 11:09 AM
    Bradahboy808
    Koby
    Kauai as why
    Mahalo for the help guys,
    I just replaced the upper ball joints last week. Also, would the alignment shop have told me if the control arm bushings were worn, since they have to adjust the lower control arm?
    It is a 4x4 as well.
  6. Aug 4, 2021 at 12:03 PM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    Regarding the popping sound, any chance the u-joint on your steering shaft is shot?
  7. Aug 4, 2021 at 1:02 PM
    Bradahboy808
    Koby
    Kauai as why
    That could be a possibility. I’ll check it out later, but only the drivers side wheel has play.
