Steering wheel wobble between 55-65mph (Solved)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lcsfletcher, Apr 9, 2020.
  1. Apr 9, 2020 at 11:17 PM
    lcsfletcher
    lcsfletcher [OP] Member
    Jacob
    2010 TRD Sport 4x4
    Hey everyone, i've scoured this forum for all other threads regarding this issue and haven't been able to pin down my issue as of yet so hopefully you guys can help me out now.
    Between 55-65mph the steering wheel begins wobbling roughly anywhere between a quarter to half an inch at its worst. Tapping on the breaks suddenly doesn't dissipate the issue, only when i speed past 75 or go below 50ish.
    Current mods to the suspension are:
    2.5" Headstrong coil lift
    Bilstein 5100's
    Believe a 1/4" driveshaft spacer
    Car Specs:
    2010 Double cab
    4x4
    100k miles
    Aftermarket FN 17x8 wheels with 0mm offset
    30" Falken wildpeaks
    What I've done so far to try and fix:
    - Balance and alignment done 2x, had them both redone 2 weeks ago and the tech said everything was still good
    - New passenger side CV axle
    - New Driver side CV axle
    - ECGS clamshell bushing for driverside CV axle
    - Checkover of all mounts and bolts for suspension and steering column that I could access
    - Replaced brake pads and rotors
    - Rotated tires
    I hope that at this point i've narrowed it down. When I move the steering wheel there is about half an inch of slop before it "contacts" and really starts moving the wheels and I can also hear a clunk coming from the engine bay when it "contacts" but I don't know where exactly. I have a hunch thats its either the gearing in the steering box or one of the steering rack bushings although I have read from other users on this forum that everything I just listed above is normal. Car is currently at 100k miles so i'm hesitant to believe that.
    Any recommendations would be awesome guys!
    4/10 Possibilities so far:
    - Bad tires (currently Falken Wildpeaks)
    - Steering rack bushings
    - Steering Stabilizer?
    - Inner tie rods
    4/18: Problem fixed!
    Replacing both inner/outter tie rods fixed the issue. Drove over 250 miles as of posting this with zero wobble issues.
    Condition of both tie rods were the same on either side when they were removed:
    Outer: Seemed good, ball joints were stiff and still had grease
    Inner: No play/slop in the ball joint but it was very easy to move up/down by hand compared to the new one being stiff.
    Hopefully that info helps out anybody whose having similar issues!
  2. Apr 9, 2020 at 11:25 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    I had a similar issue. Steering wheel shake was intermittent at highway speeds. I bought the truck with a spacer lift and add a leaf. I replaced all bushings in the front end and steering rack with poly bushings. Seemed to solve the problem. I did however also put different tires and wheels on at the same time, so I can’t necessarily rule that out either.
  3. Apr 9, 2020 at 11:30 PM
    lcsfletcher
    Jacob
    2010 TRD Sport 4x4
    Steering rack is definitely on my mind as a possibility solely because of the clunk, but I have read other users using Falken tires having vibration issues. What tires did you end up switching too?
  4. Apr 10, 2020 at 1:48 AM
    TacoJoeBro
    TacoJoeBro Well-Known Member
    Not Joe
    Midwest
    12 DCSB OffRoad
    6112/5160 Icon RXT JBA KO2
    The clunk would definitely have me looking at bushings especially the rack. Have you tried a tire rotation yet? I had a problem with a set of Wildpeaks on the wife's 4Runner a few years ago. After a few rebalance attempts, I got rid of the Wildpeaks. And the shake/vibes stopped. Might be an out of round tire. Balance doesn't rule that out. Keep in mind, you can balance a square or triangle for that matter.
    Alexely999 likes this.
  5. Apr 10, 2020 at 7:02 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Does it go away in 4x4 now? If not I’d bet on tires/wheels. I had a bad vibration from 45-60mph had wheels/tires balanced, rebalanced, rebalanced again, techs keep telling me they’re fine, I swapped the wheels for some stock ones SMOOTH AS BUTTER.
    the clunk may or may not be related, could always be a separate issue. If it is related that would point me towards an issue with the steering system, not wheels/tires. I would get under the truck and check for any play while someone else sits in the cab and turns the steering wheel back and forth.
  6. Apr 10, 2020 at 10:51 AM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Mine turned out to be a bent rim.
    ToyotaDriver likes this.
  7. Apr 10, 2020 at 2:48 PM
    ToyotaDriver
    Idaho
    i had a set of laufens I took off my other tacoma. Good all terrains for mostly highway driving. Do well in the snow and dirt. Steering rack bushings were my big concern. Decided to do the rest of the front end bushings because I had it apart.
  8. Apr 10, 2020 at 2:52 PM
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    Swap your wheels front to back and back to front. If the vibration stops in the steering wheel and you start feeling it in the seat, then you know it’s a wheel/tire problem.
    Biscuits and LoveableWerewolf like this.
  9. Apr 10, 2020 at 2:57 PM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    My falkens do vibrate a bit more, but in my experience they just need rotated more. I would defenitly rotate before anything just because its free.
  10. Apr 10, 2020 at 4:33 PM
    lcsfletcher
    Jacob
    2010 TRD Sport 4x4
    Thank's for all the replies guys! The vibes don't go away when the truck is in 4x4. This issue was happening with the stock rims before I got my new ones and I had the tires rotated a month ago as well. For now i'm going to try and check out the steering rack bushings and then possibly new tires. Have been planning on going bigger anyway since I got the lift.
    QuicksandTaco[QUOTED] likes this.
  11. Apr 10, 2020 at 4:36 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Hang on. Why did no one at any point mention that he should check his wheel balance?
    OP, did you check your wheel balance? These trucks are so sensitive that they require a roadforce balancing. Go get 'er done.
    sentientprogram likes this.
  12. Apr 10, 2020 at 4:40 PM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
  13. Apr 10, 2020 at 4:41 PM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Wait.... now I’m thinking you were being sarcastic... crap.
  14. Apr 10, 2020 at 4:42 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    :rofl:
    That's what I get for skimming.
  15. Apr 10, 2020 at 5:06 PM
    lcsfletcher
    Jacob
    2010 TRD Sport 4x4
    I should have been more specific when I said wheels and alignment done, my bad. I have had the wheels balanced twice with the latest being 2 weeks ago and the tech (overland buddy of mine) said that they were still in balance.
  16. Apr 10, 2020 at 6:07 PM
    QuicksandTaco
    Cody
    Oregon
    Were they road force balanced? Some times they can be in balance until you put force on them. I know that I’ve had issues with vibration and it didn’t go away until they road forced.
    12TRDTacoma likes this.
  17. Apr 10, 2020 at 6:51 PM
    lcsfletcher
    Jacob
    2010 TRD Sport 4x4
    Unsure about that part of it, ill ask my buddy. Another thing about the wobble is that it doesn't always occur between those speeds. On my drive to work today every time I hit the between 55-65 it began the shake but on my drive home just now it barely started vibing at only one point. If it were the tires causing the vibration I would assume it would start vibing every time I hit those speeds.
  18. Apr 10, 2020 at 6:52 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    MICHELIN Defenders is your answer
  19. Apr 10, 2020 at 7:09 PM
    tacokarl
    tacokarl Big Blue
    Karl
    Connecticut
    2008 Pre-Runner SR5 DCLB
    +1 about to pull the trigger on my second set. Got about 75k out of the fist set.
    BillsSR5[QUOTED] likes this.
  20. Apr 10, 2020 at 9:19 PM
    QuicksandTaco
    Cody
    Oregon
    Oh fuck dude, it just came to mind, have you checked your rotors? Warped rotors could definitely be the culprit.
