Steering wheel wobble comes and goes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anthemAnathema, Nov 10, 2023.
  1. Nov 10, 2023 at 12:23 PM
    anthemAnathema
    anthemAnathema [OP] Well-Known Member
    2013 4.0 6MT Access Cab TRD Offroad
    Elka 2.5 w/ DSC RCI Skids AP Expedition Leafs Leer 180
    I have an inconsistent wobble in my steering wheel that comes and goes, seems to be the worst between 45-55 mph, but isn't always there at those speeds. When it does wobble, it's about 3/4", but a lot of the time it doesn't wobble at all. It only wobbles on straight aways, never in corners.
    With tires off the ground and hands at 6 and 12 o'clock there is no play (so not LBJ?) but at 3 and 9 o'clock there's definitely some play (1/2-1"). It seems the movement comes from the CV axles not the tie rods (wobble is there in both 2hi and 4hi), but when doing this on the drivers side it looks as if the movement translates up to what I'm assuming is the steering linkage.
    It's not a tire balance, I went up to 33s a couple months ago and the wobble didn't change, even after two balancings.
    It's also not the UCAs, I just changed them today (Xaxis bushings on SPC UCAs had gone bad). Changing the UCAs did reduce the wobble a bit, but definitely didn't eliminate it.
    At rest, my steering wheel also has a bit of play side-to-side, about 1-1.5".
    Any recommendations on diagnosing this problem?
  2. Nov 10, 2023 at 1:02 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Steering rack, steering shaft ujoints or tie rods
    Grab a rope and tie middle to wheel and both ends out the windows so you can go under and pull rope to watch things
    anthemAnathema[OP] likes this.
  3. Nov 10, 2023 at 1:08 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Have you had your axle out lately?
    Throwing something else out there as you've had other things apart.
    I'd start with double checking to make sure everything is properly torqued.
  4. Nov 10, 2023 at 8:48 PM
    Mudsock
    Mudsock Well-Known Member
    Indiana
    2010 2.7 4x4
    Check the u joints in the steering shaft. There is one down close to the rack and pinion. There is also one just below the steering wheel.
    If you don’t mind using non-oem, eBay has the replacement parts for cheapness.
  5. Nov 11, 2023 at 6:17 AM
    anthemAnathema
    Thanks for the thoughts so far, gonna give these a shot today.
  6. Nov 11, 2023 at 9:54 AM
    lr172
    lr172 Well-Known Member
    ‘11 DCLB 4.0 Auto
    175K on my new '11 DCLB. Had three issues. Some idiot at the toyota dealer put power steering fluid in it. Flushed it out and replaced with ATF and steering got smooth; Very stiff when I got it. Still had play though. Had son wiggle steering wheel and observed slop. Two problems emerged. Worn and sloppy u joint on lower steering shaft. Very easy to observe through wheel well. 2nd, I could see the input shaft move without the steering arms moving. There was slop in the internal guide bushing. Difficult to get in there, but tightened down the large adjustment nut (maybe 1/8 of a turn or so). Instead of dropping the rack, I made a special tool to get in there to tighten the nut. Feels like a new truck now. Tighten nut a little and observe. Keep doing it until the slop is gone. This was not the original rack. Probably a crappy reman, so this may not be an issue with OEM toyota racks. Those u joints are not sealed, so prone to wear as the grease works its way out over the years.
  7. Nov 11, 2023 at 10:05 AM
    lr172
    ‘11 DCLB 4.0 Auto
    Be prepared for an alignment tough. I got the dorman version and the clocking of the two ends was off by about 30 degrees.
  8. Nov 13, 2023 at 2:14 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    I pretty much have the same issue , with the front end off the ground and grabbing the tire at 3 and 9 it moves about a 1/2” ish . I have to crawl under and see what’s going on . The steering wheel wobble comes and goes usually around 55ish .
  9. Nov 13, 2023 at 2:40 PM
    IndianaTaco83
    IndianaTaco83 Well-Known Member
    2005 Tacoma Double Cab / 2021 Tacoma Double Cab TRD Pro
    Sounds like tie rods.
  10. Nov 14, 2023 at 5:57 AM
    lr172
    ‘11 DCLB 4.0 Auto
    It could be either or both of the things I mentioned above, but could also be tie rod issues (typically the ball joint on the tie rod end). The items above, you observe the upper steering shaft moving with NO movement of the tie rods. With the later, you observe the input shaft and tie rod arms moving in unison with no movement of the wheel. Pretty confident that the steering shaft u joint is a common failure point on the older trucks, but then again, so are tie rod ends. 1/2" tire movement is A LOT for a bad tie rod end, so don't think that is the issue. Usually the play is slight. Also look for worn bushings that secure the rack to the frame. The rack moves around inside of it's bushings, allowing drifting at high speeds. I think this may have only been an issue on the 1st gens with the old design.
    igno1tus[QUOTED] likes this.
  11. Nov 15, 2023 at 1:46 PM
    igno1tus
    Haven’t had a chance to really look at it yet , is this steering shaft ujoint a pain to repair ? Expensive ? Do you have to get an alignment ?
    I already have taken it to 2 shops and haven’t gotten anywhere with it at all . :mad:
  12. Nov 15, 2023 at 2:10 PM
    2007 4x4
    2007 4x4 Well-Known Member
    07 4x4 DCLB SR5 and 06 Reg Cab 5 Lug
    have you tried new wheel bearings?
    i had a wobble at about the same speed, inconsistently as well and replaced tie rods, carrier bearing, drive line angles, and the needle bearing bushing..nothing solved my problem
    vibes went away when i replaced front wheel bearings on both saides
    good luck
  13. Nov 15, 2023 at 6:30 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Look up the zip tie mod too, for the cab side of the steering column
    igno1tus likes this.
  14. Nov 15, 2023 at 8:41 PM
    lr172
    ‘11 DCLB 4.0 Auto
    It is not fun but not terribly difficult. Getting the coupling end off the rack took some prying and banging. Middle sleeve was work as well to get it to slide up the intermediate shaft splines. Both due to rust. Part is $40, however if the don’t get the two couplers clocked correctly, like mine, a toe adjustment is required to get the steering wheel centered. Oem is likely dead accurate replica, bot 5X in cost.
  15. Nov 15, 2023 at 9:35 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Had same problem .Have someone rock steering wheel back and forth and physically feel inner tie rods for movement. When I checked mine grabbing wheel and checking couldn't feel anything but when grabbing tierod with someone rocking steering there was play .No wobble after changing tierods
    winkel likes this.
  16. Nov 18, 2023 at 12:38 PM
    Mudsock
    Indiana
    2010 2.7 4x4
    Username is oddly appropriate.
  17. Nov 18, 2023 at 4:03 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    This would be my recommendation, have someone wiggle (yes, wiggle) the steering wheel while you lay under the truck. Put a hand on everything that moves and see what seems to be moving at different rates.
    hemitruk[QUOTED] likes this.
