Steering wheel wobble
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 3rd gen taco tony, Nov 14, 2016.
  1. Nov 14, 2016 at 8:21 AM
    3rd gen taco tony
    3rd gen taco tony [OP] New Member
    Anthony
    2016 trd crew cab inferno Tacoma
    6 inch bds coil over suspension lift 33x12.50 r18 18x12 fuel avenger wheels
    Hey guys new to the site I see everyone pitches in and I know threads are made already for this problem but I own a 2016 Tacoma with a 6 inch fox coil over lift (coils arnt adjusted to ride height) and I got wheel wobble decently bad around 70+km and I recently got my tires re balenced that got rid of some of the wobble but still about 30% wobble left I don't have hub centric rings my U a angle is at 19% stock is 9% not sure if that would be part of the issue but I'm looking for possibilities thank you
  2. Nov 14, 2016 at 9:40 AM
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    Did you have an alignment done? if tire balancing removed some wobble, logic would suggest tires are the problem.
  3. Nov 14, 2016 at 10:17 AM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    6 inch suspension lift!?!? wheels should either be hub centric or they need rings. not much else to keep it centered, lug nuts alone wont do it. and what in the heck is a "U a" are you measuring at an angle? or do you mean your front axle? that will cause a lot vibe if it really is a 4wd with 6" suspension lift. 2" caused my front diff to drive me nutty with humming
    ChadsPride likes this.
  4. Nov 14, 2016 at 10:47 AM
    Scruffie
    Scruffie Well-Known Member
    Arsie
    Surrey B.C Canada
    2016 QuickSand Access TRD OR Manual
    265/75/16Dura,SSO Hybrid,X20,CruisinSliders,Skids
    Common problem with lifted trucks and front caster not able to be returned to specs. Incorrect caster will cause shimmy.
  5. Nov 14, 2016 at 3:40 PM
    3rd gen taco tony
    Anthony
    Sorry I meant uca** angle because of the coils not being adjusted but I have gotten an alignment also helped with the wobble a little bit but still have that 30% ish wheel shake I will buy a set of hub rings so if that is the case and yea I only have Hub centric nuts that's it
