Steering wheel wobbling
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bears2020, Nov 5, 2020.
  1. Nov 5, 2020 at 2:28 AM
    Bears2020
    Bears2020 [OP] Member
    Pete
    2020 cement 4x4 TRD double cab
    Cargo lights
    Hi I just lifted my 2020 Tacoma TRD off rd. 3/2 spacer lift new rims tires now at 37 to 42 steering wheel wobbles just little then goes away. Had front end was aligned after shop install of leveling kit. Any suggestion ? I plan on going back to the shop today see what they say thanks
  2. Nov 5, 2020 at 3:33 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Does the wobble happen at specific speeds ?? If so sounds like u need to rebalance and road force the new tires to rims . Might be out of balance .
    wilcam47 and Bears2020[OP] like this.
  3. Nov 5, 2020 at 3:36 AM
    Bears2020
    Pete
    Cargo lights
    Thanks I’m going back some time today just picked it up last night from the shop it just happened around 37 to about 42 intermittently hmm
    Winch likes this.
  4. Nov 5, 2020 at 7:09 AM
    N5J_Taco
    N5J_Taco Well-Known Member
    I had the same issue when I lifted my truck. Had it realigned several times but the steering wheel wobble never went away till I replaced my factory UCA's and was able to moved my caster number to 3.0 to 3.5.
    71tattooguy likes this.
  5. Nov 5, 2020 at 7:37 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    what type of tires?
  6. Nov 5, 2020 at 7:43 AM
    Bears2020
    Pete
    Cargo lights
    Nitto Grapplers 285/70/17
  7. Nov 5, 2020 at 7:48 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    OP you have alignment numbers?
  8. Nov 5, 2020 at 7:53 AM
    Bears2020
    Pete
    Cargo lights
    No I have no number had a front end shop did the work. He lowered the air pressure and said drive it a week bring it back we can try rebalance the tires again.
  9. Nov 5, 2020 at 6:07 PM
    N5J_Taco
  10. Nov 5, 2020 at 6:48 PM
    K.Ray
    K.Ray Well-Known Member
    East TN
    2016 Toyota Tacoma TRD Off-Road, 6sp Manual, Quicksand
    None
    Roll under your truck on the drivers side and grab the inner CV assembly that attaches to the differential.
    Give it a good wiggle.
    Did it move? It’s not supposed to.
    Now replace your needle bearing with a new ECGS bushing. Enjoy wobble and vibration free driving!
    mchertel and Bears2020[OP] like this.
  11. Nov 6, 2020 at 1:00 AM
    juicedstang999
    juicedstang999 Well-Known Member
    rich
    99 TRD SR5 AUTO XTRA CAB
    6" RC Lift 33's 200k+ club
    Rebalance wheels/tires
    Bears2020[QUOTED][OP] likes this.
  12. Nov 11, 2020 at 5:16 PM
    Bears2020
    Pete
    Cargo lights
    Bears2020Hi I was reading a post about adjusting lights after lift . I have a 2020 Tacoma TRD off rd just had a 3/2 lift I went from 265/75/16 to 285/70/17 with led bulbs legal leds. But getting lights flash from oncoming traffic . I know how to adjust but not sure the high? Should I go 3 inches lower? Thank in advance if you know
  13. Nov 11, 2020 at 5:30 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Is the anti wobble fluid low? I'd start there, if not then I'd check wheel balance.
    Bears2020[OP] and Boghog1 like this.
  14. Nov 11, 2020 at 5:33 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The service manual has precise instructions for setting the height of the beam cutoff at a specific distance from the wall. Follow that and you shouldn't blind oncoming traffic.
  15. Nov 11, 2020 at 5:55 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I set mine *exactly* per the spec. It's incredible how accurate it is. I routinely watch my headlights bounce on the trunks of cars in front of me, happy as a clam knowing I'm not blinding anyone.
    K.Ray and 3JOH22A[QUOTED] like this.
  16. Nov 11, 2020 at 6:18 PM
    mchertel
    mchertel Well-Known Member
    Mark
    Colorado Springs CO
    2020 Tacoma Off-road
    Toytec 2 inch boss lift
    My wife’s 2021 4Runner came from the factory with LED bulbs in projection lenses. And my 2020 Tacoma came from the dealer with Miramoto LED bulbs in the stock projections so dunno.
  17. Nov 11, 2020 at 6:26 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    If it goes away above 42 mph, then tire balance probably isn't to blame. A 3" spacer lift on stock UCAs? Your caster is probably near zero, which will explain the steering wheel wobble. Get aftermarket ball joint UCAs (ball joint because they have less friction than uniball UCAs) to get more caster. Beware it'll cost $200-300 in shop labor (takes twice as long to swap UCAs than to swap front shocks).
  18. Nov 12, 2020 at 4:18 AM
    K.Ray
    East TN
    None
    At minimum you can:
    - park on level ground and turn low beams on to shine on a wall in front of you
    - measure from the ground up to the center of your protection lens.
    - now measure from the ground up to the beam cuttoff on the wall.
    - depending on the distance you parked away from the wall, the lens cutoff height should be lower than the projection lens height.
    - AKA; your low beams should be pointed downwards slightly to not blind oncoming traffic
    I would recommend starting your own thread next time since this conversation has nothing to do with headlights or lift kits.
    Bears2020[QUOTED][OP] and Chew like this.
  19. Nov 12, 2020 at 5:57 AM
    K.Ray
    East TN
    None
    I have tested this this theory and have drawn the below conclusion:
    My 2016 truck with aftermarket (expensive) LED bulbs throws the exact same beam as my buddies 2020 truck with stock LED bulbs in the projection housing.
    No difference in beam pattern, beam height, bulb LED width or positioning, and no difference in housing part number when searched on parts.toyota.com.
    The difference we can see is the wiring harness is controlled by the ECM, so no wiring lead is required like seen on most aftermarket bulbs. The factory just plugs a simple LED bulb into the housing.
    The factory LED bulbs are passively cooled with heatsinks. The factory LED bulbs have three emitters on each side of the stalk.
    I am not an engineer and offer no scientific research here so ymmv. It does appear that due to the nature of the projection housing and cutoff that Toyota deemed it fit to simply retrofit LED units as well.
  20. Nov 12, 2020 at 6:53 AM
    mchertel
    Mark
    Colorado Springs CO
    Good to know, I never get "flashed" with the Tacoma having the after market LED's. I have heard they are illegal which is weird because I bought it brand new from the dealer that way....maybe Colorado doesn't really care?
