Steering wheel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toyman53, Apr 13, 2013.
  1. Apr 13, 2013 at 6:41 AM
    Toyman53
    Toyman53 [OP] Member
    NC
    08 toyota tacoma
    3" lift, lt325 60 r18 tires
    I have a 08 tacoma with a stranded steering wheel can I change
    It to a stereo controlled steering wheel where can I buy one at
    Or is it worth the problem. Thanks
  2. Apr 13, 2013 at 6:44 AM
    Toyman53
    NC
    08 toyota tacoma
    I have a 08 tacoma standard steering wheel I would
    Like to change it into a stereo controlled steering
    Wheel where can I buy one or is it worth the trouble
  3. Apr 13, 2013 at 7:05 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    If its stranded, I'd call Wilson to keep it company.
  4. Apr 13, 2013 at 10:43 AM
    DevL
    DevL Well-Known Member
    You can buy either of the power units. The left one is the main one and the right one plugs into the left one. You can buy them from any dealer. I use mine with an aftermarket deck.
  5. Apr 14, 2013 at 9:44 AM
    Toyman53
    NC
    08 toyota tacoma
    I guess I should be more clear I need the steering wheel also
  6. Apr 14, 2013 at 8:49 PM
    DevL
    You need the steering wheel also? Where is your current one?
  7. Apr 14, 2013 at 8:52 PM
    xaqori
    xaqori Grammer knotsy
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    ARB lockers and 4.88s front and rear, OME 886s, Dakars, etc., Safari Snorkel, 17"Fuel Revolvers w/ 35x12.50r17 KM2s, fenders cut 3" all around, Pioneer AVH-P4400BH w/ Backup cam, CB/PA (PA Installed), Weathertech Digis, Foglight anytime, AP: front bumper, skids, and pack rack, custom sliders, Warn 9.5XP, dual VIAIR 480Cs with a 2.5gal tank, OTRATTW switches galore, URD y-pipe, RCI skids, LF 240s, etc.
    x2 :confused:
  8. Apr 15, 2013 at 3:58 PM
    Toyman53
    NC
    08 toyota tacoma
    Ill just cancel here I ask a simple question needing
    Help I don't need a smartass
  9. Apr 15, 2013 at 6:39 PM
    DunhamAll
    DunhamAll Well-Known Member
    Jordan
    Baltimore, MD
    '12 Access cab, MT, TRD OR
    Rear diff. breather, BHLM, Wet Okoles.
    To be fair you never did explain where your steering wheel was stranded. Providing the last known location of the steering wheel could be important in getting your question answered. Have you even sent out a search party yet, or did you go all Helen Hunt and move on to finding a new steering wheel?
  10. Apr 15, 2013 at 6:47 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Do you have blanking plates where the buttons are, or a continuous airbag cover?
  11. Apr 15, 2013 at 6:53 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar/Ontario, CA
    08 TRD 2wd converted to 4wd
    Estock
    if your truck did not come with steering wheel controls you need the clockspring from one that has controls and then controls with new airbag...
  12. Apr 15, 2013 at 6:54 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
