Steering wheel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dranibal, Oct 28, 2015.
  1. Oct 28, 2015 at 6:34 AM
    Dranibal
    Dranibal [OP] Member
    Anival
    2008 tacoma v6 crew cab
    Hello
    Ive just bought a 2008 tacoma and there is a problem, the steering wheel shakes right and left at low speed and most on irregular surfaces ,feels terrible, like the truck move the steering wheel not the driver. It has aligned allready but the problem is still there
    Any ideas what can i do?
    Im about to sell it because of that
  2. Oct 28, 2015 at 6:35 AM
    diverdale
    diverdale #sosconceptscrew
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Fox 2.5 Coilovers, Fox 2.0 Rear Resi, Icon 3 Leaf AAL
    Bad alignment will not cause shaking only pulling one direction or the other. Shaking is usually caused by a balance issue or the tires are severely worn.
    txtaco87 likes this.
  3. Oct 28, 2015 at 6:43 AM
    txtaco87
    txtaco87 Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    i agree with @diverdale , when the tires are chopped or the wheel balance is off pretty good, it will cause the shaking and pulling while driving.
    Dranibal[OP] likes this.
  4. Oct 28, 2015 at 6:45 AM
    Dranibal
    Anival
    Ok ill try new tires any make you recomend? Yeap in fact they are in bad shape i hope
  5. Oct 28, 2015 at 6:46 AM
    Dranibal
    Anival
    Sorry i hope thats the cause and not a major steering trouble
  6. Oct 28, 2015 at 6:47 AM
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    personally i like the BF Goodrich All Terrain KO series. great all around tire and you can get it in the factory size or larger.
    im running them in 285/75R16
  7. Oct 28, 2015 at 4:01 PM
    Capt Jrod
    Capt Jrod Well-Known Member
    Jarrod
    Northern Ohio
    15 WHITE DCSB 4x4 TRD SPORT
    Rotate them first and see if it helps... Maybe balance, bent rims, come on guys... We should check a few things before spending money. TW tire recommendations are usually Michelin or coopers. I would recommend a four wheel alignment $60 around here in Ohio. I always get it done with a new set of shoes. If something is worn too far then they will let you know
