Steering
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Burlingtonmarine1845, Mar 7, 2018.
  1. Mar 7, 2018 at 12:47 AM
    Burlingtonmarine1845 [OP] New Member
    Larry
    2010 Tacoma. 4x4
    I have a 2010 Tacoma.4x4.Put new tires on about 4 months ago.Got it aligned too.Been running great Last couple days been harder to turn the steering wheel.Going straight is perfect.No pulls drives straight down the road.When I turn on curves or around a corner there is quite a but more resistance on the steering.Not going straight though.Pump makes no whining noise.Rotated tires still makes no difference.Any ideas what's up.
  2. Mar 7, 2018 at 4:41 AM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    Check for binding on the steering intermediate shaft ujoint. Believe there was a TSB awhile back for this.
