Step Removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ThomasMore66, Feb 24, 2015.
  1. Feb 24, 2015 at 1:23 PM
    ThomasMore66
    ThomasMore66 [OP] We can't stop here, this is bat country!
    Dallas/Fort Worth & Durango
    So, I have taken off my chrome steps that came with the truck. Does anyone have a plug or screw that fits the holes in the body? I'd like to plug them so they don't get filled with crap and rust.
  2. Feb 24, 2015 at 1:25 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    I plan on using silcone or just using the bolts that came with the tube steps. But its too damn cold out to do it right now.
  3. Feb 24, 2015 at 1:27 PM
    devkurf
    devkurf Member at Large
    midwest
    those little plugs shouldn't be too bad at the dealer, I'm assuming they can get them
  4. Feb 24, 2015 at 1:28 PM
    ThomasMore66
    I saw a picture on-line of some sliders and there were some straight-edge screws filling those holes. I wasn't sure if that was a plastic piece from the dealer or a regular screw. I looked on-line for a part number from Toyota and came up dry.
  5. Feb 24, 2015 at 5:35 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    Put the bolts back in the holes. Now you have the hardware if you ever need it again.
