step up from pro sema rims.. offset wise
Discussion in 'Wheels & Tires' started by bludweiaer, Aug 13, 2017.
  1. Aug 13, 2017 at 2:31 PM
    bludweiaer
    bludweiaer [OP] Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    so i have a set of sema rims on my pro,, my question for the offset and backspacing experts is,, going to an 8 in wide rim, and moving 1/2 out and 1/2 inwards... seeing as the sema rims is 7 in wide...keeping the same in and out , 8 in. rim instead of 7 in wide rim... its confusing when considering a aftermarket rim, want to order the right specs,, thanks
  2. Aug 14, 2017 at 9:20 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    The exact specs for what you want to do is an 8-inch wide wheel with a +4mm offset. I'm not sure any wheel manufactures offer wheels in these dimensions though. 17x8 with 0 offset (assuming you're looking to stay 17-inch) is pretty common and will sit pretty close to what you're looking for.
    Here's a wheel visualizer/calculator that you may find useful. 17x8 6-139.7 Wheel Options | Discount Tire Direct
