Step when tailgate is down
Discussion in '3rd Gen. Tacomas (2016-2023)' started by farmtacoma, Feb 8, 2021.
  1. Feb 8, 2021 at 10:41 AM
    farmtacoma
    farmtacoma [OP] Date Farmer
    Julia
    Twentynine Palms, California
    2021 Cement TRD OR DCLB 4x4 & 2018 Silver SR ACLB 4x2
    Do you guys have any recommendation for a step for loading the bed, when tailgate is down?
    For my search I found this product only
    https://www.autoanything.com/hitch-bed-accessories/69A5284A0A0.aspx
    But I can't tell if I need the standard or the XL version. It stays, that standard might not work for underbed spare tire.
    Appreciate the help.
  2. Feb 8, 2021 at 10:45 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    I think the OEM bed step is much better. Flips down or back up with your foot, don’t have to put on or take it out. Cost a little more but love mine.
  3. Feb 8, 2021 at 10:45 AM
    farmtacoma
    Julia
    That is on side of bed only, right?
    71tattooguy likes this.
  4. Feb 8, 2021 at 10:47 AM
    tclavell
    Troy
    Phoenix, AZ
    G70
  5. Feb 8, 2021 at 10:47 AM
    davidstacoma
    David
    NC
    Right
  6. Feb 8, 2021 at 10:57 AM
    farmtacoma
    Julia
    StayinStock and davidstacoma like this.
  7. Feb 8, 2021 at 11:03 AM
    cop414
    cop414 Well-Known Member
    Tim
    Central PA
    2022 Blue Crush DCSB Sport
    Can’t beat the old man folding OEM step. 90456170-FF7D-44C5-B391-5ADC37213BAD.jpg
  8. Feb 8, 2021 at 11:04 AM
    farmtacoma
    Julia
    Works for old women too :D
    Ordering it now, then need to see if I can install it myself
    daveeasa likes this.
  9. Feb 8, 2021 at 11:08 AM
    davidstacoma
    David
    NC
    The bolts are a little hard to get loose, I used a breaker bar and that made it easy so if you have one it will help.
  10. Feb 8, 2021 at 11:10 AM
    cop414
    Tim
    Central PA
    :thumbsup:
    Install isn’t too hard but you will need a long socket extension and a torque wrench. You’ll be removing and reinstalling the two bolts that hold the bumper frame on so I’d suggest the torque wrench.
    Also agree with the breaker bar to remove those bolts.
    farmtacoma[OP] likes this.
  11. Feb 8, 2021 at 11:10 AM
    farmtacoma
    Julia
    Breaker bar + WD40?
  12. Feb 8, 2021 at 11:10 AM
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    How much weight will that step hold? Asking for a friend.
    davidstacoma and farmtacoma[OP] like this.
  13. Feb 8, 2021 at 11:13 AM
    farmtacoma
    Julia
    300lb weight load, per Toyota
  14. Feb 8, 2021 at 11:17 AM
    woodsy
    Ohio
    Ok thanks. That should hold me...I mean my friend.
  15. Feb 8, 2021 at 11:17 AM
    farmtacoma
    Julia
    :D
  16. Feb 8, 2021 at 11:21 AM
    davidstacoma
    David
    NC
    That’s a good point, I should have said the step is molded plastic with only the center in supported, and I was expecting a full metal support with a rubber cover like a pedal type. It’s sturdy but you want to put your foot toward the center and not the very outside end. If you are stepping up with a heavy load then you may indeed want to go with the design you were looking at (depending on its rating). The OEM step is primarily just for you stepping up onto the bed.
  17. Feb 8, 2021 at 11:22 AM
    farmtacoma
    Julia
    Usually we have large boxes we are loading on to bed
  18. Feb 8, 2021 at 11:25 AM
    davidstacoma
    David
    NC
    Well when I do that I don’t carry the box and step up with it, I set it on the tailgate and slide it in. :D Then just step up into the bed when you want to slide your boxes forward.
  19. Feb 8, 2021 at 11:28 AM
    farmtacoma
    Julia
    I added a bed mat to the truck, first time I owned the mat. Then I realized, now I can't slide my boxes on it :annoyed::annoyed:
    Panchovilla6192002 likes this.
  20. Feb 8, 2021 at 11:29 AM
    smdcbr
    smdcbr Well-Known Member
    Passaic county, NJ
    2016 Blue TRD Sport AC M/T
    On your '21 you shouldn't need WD40. I didn't when I put one on my '16 in '16
