Steps for making a right turn for stick shift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bballrules, Jun 8, 2009.
  1. Jun 8, 2009 at 5:09 PM
    bballrules
    bballrules [OP] Member
    Irvine, CA
    09 PreRunner SR5
    Hey, I have a question about manual driving. What is the correct step to do throughout the process of making a right or left hand turn on a green light? Say I am going 40 mph in 4th gear. What do I do before and after the turn? Can someone explain the process? Thanks! :)
  2. Jun 8, 2009 at 5:11 PM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    Push in clutch, downshift to 2nd and brake to slow down. As you've slowed to about 25 start letting out the clutch to help slow you and then make your turn. As you accelerate you upshift as normal. Always take corners under power, never coast.
    Why such a noob question?:confused:
  3. Jun 8, 2009 at 5:15 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    There is no true "correct" way. Drive the truck in which the way is comfortable to you. Personally, I would downshift to third while braking before the turn, then to 2nd when I enter the turn, and shift to third as I exit the turn.
  4. Jun 8, 2009 at 5:15 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    +1 for GoBlue's post.... just go for second gear, slow yourself down with second gear once you're slow enough that you don't over-rev it. Take the corner in second gear and take a nice easy power out. Like he said earlier, don't coast corners.
  5. Jun 8, 2009 at 5:20 PM
    GoBlueFan
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    something to think about...you are putting twice the wear/tear on your rear tires when you use a lot of engine braking. .02
    Nothing wrong with driving that way...
  6. Jun 8, 2009 at 5:24 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    My last set of BFG's last over 70k miles.............before the rear driver side blew. :eek:
  7. Jun 8, 2009 at 5:34 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    Uuumm you shift down one gear at a time while on the brakes, making sure not to down shift too fast and not have your rpm's get high. Down shift each time when your rpm's get low and the engine rpm's will help it slow down. You should practice out in a field or a wide open area, with someone that has experience. I think the best way for someone to learn about this is to do it first with a dirtbike. Also try not to shift into neutral. There are a lot of differant ways but make sure not to down shift to fast if your doing normal braking but if you have to stop fast you may have to shift down fast.
  8. Jun 8, 2009 at 5:41 PM
    bballrules
    Irvine, CA
    09 PreRunner SR5
    hey, thanks for the help above. so i always suppose to be in second gear before i enter the turn right? or do i go into 2nd gear while turning? also, i was trying to search and people were talking about rev-matching during downshift. do you guys rev-match when turning with the steps above or do you just put the shifter into second gear and just easing off the clutch while using no gas pedal at all? thanks again!
  9. Jun 8, 2009 at 5:47 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Just try it either way dood. You will find they way you like to drive it. Don't worry, the truck will tell you if what you are doing is wrong. Stay away from the rev matching until you develop a driving style.
  10. Jun 8, 2009 at 5:51 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    Don't downshift during a turn, it could upset the trucks handling. Finish your shifting before the turn.
  11. Jun 8, 2009 at 6:00 PM
    BakoTruck
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    98tacoma27 makes a good point, develop a driving style first. How fast your going around a turn will determine what gear you need to be in. It just takes some driving time to determine what gear you need to be in. If you come out of a corner in too high of a gear your car will have a harder time accelerating to driving speed.
  12. Jun 8, 2009 at 6:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Wait......Our trucks can TURN!?
  13. Jun 8, 2009 at 6:10 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    :burnrubber:Works for me.:laugh:
    :rofl:
  14. Jun 8, 2009 at 6:41 PM
    BakoTruck
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    She's going to the early bird special! :D needs to get there before 5:00
