Steps on replacing spindle?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDBandit, Jul 23, 2011.
  1. Jul 23, 2011 at 6:44 PM
    TRDBandit
    TRDBandit [OP] TACOMANATOR
    Justin
    CRAWLORADO
    07 Dbl Cab TRD O.R. Dark Blue
    Afe Stage 2 CAI Tinted windows Many to come
    If i can get ahold of a new one. soon ill take a stab at replacing it myself. Any info helps guys!
  2. Jul 23, 2011 at 7:02 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
  3. Jul 23, 2011 at 7:05 PM
    08pretaco
    08pretaco IG @14burrito
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Check suspension stickies. One in particular might help
  4. Jul 24, 2011 at 10:53 AM
    TRDBandit
    Justin
    CRAWLORADO
    Whats a sticky? lol
  5. Jul 24, 2011 at 10:54 AM
    TRDBandit
    Justin
    CRAWLORADO
    Is the spindle the same thing as the steering knuckle?
  6. Jul 24, 2011 at 10:59 AM
    08pretaco
    Oliver
    az
  7. Jul 24, 2011 at 11:06 AM
    TRDBandit
    Justin
    CRAWLORADO
  8. Jul 24, 2011 at 11:16 AM
    08pretaco
    Oliver
    az
    Yup not much to it. Remove wheel, take off caliber, remove rotor, loosen 4 bolts holding hub into spindles, remove hub, take off upper ARM and lower ARM bolts and reverse for install.
  9. Jul 24, 2011 at 11:20 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    You may need a ball joint separator or a 2-jaw gear puller to remove the upper ball joint. I prefer a 2 jaw gear puller..less potential for damage to the ball joint boot.
  10. Jul 24, 2011 at 11:20 AM
    TRDBandit
    Justin
    CRAWLORADO
    Ya man. The shop wants to charge close to 1,000$ to do it. Screw that. I would rather do it myself and learn something ya know. Im sure with the thread you sent Ill do it in a day.
