Steptember Sale!
Discussion in 'Automotive Group Buys' started by RealTruck, Sep 7, 2022.
  1. Sep 7, 2022 at 10:07 AM
    RealTruck
    RealTruck [OP] Well-Known Member Vendor
    Happy Steptember Tacoma World!
    We are proud to offer a very special deal for you all this month! We have partnered with N-Fab and Go Rhino on this one to bring you some outstanding steps with unbeatable pricing!
    Pricing is going to be by PM or email only to take part of this huge sale!
    I am going to highlight a few of our top sellers but if there is another N-Fab or Go Rhino board or step that you are interested in please don't hesitate to reach out as this discount does apply to their entire line! We specifically chose these two brands to work with due to the quality of their products and the ingenuity their steps offer.
    We will be running this special for the month of September, as the name suggests, so do not wait to take part in this limited offer!
    GO RHINO VERTEX V3 SIDESTEPS
    • Made with light-weight aluminum
    • Textured black powder-coat finish
    • 5” step width
    • Polymer step pads feature aggressive tire-treading for ultimate traction
    • Mounts to rocker panel on most applications
    • Easy, no-drill application
    • Extruded aluminum core holds up to 300 lbs. per step pad (600 lbs. per side)
    • 5-year warranty
    GO RHINO RB10 RUNNING BOARDS
    • Constructed from one piece of 16 gauge zinc coated steel
    • Thickness offers optimal strength to weight ratio.
    • Zinc coating seals the steel, offering additional corrosion resistance
    • They come with a rubberized powder coat that adds to the grip of the step area considerably and increases durability
    • 5 year warranty
    • 5” wide
    • No drill
    N-FAB TEXTURED BLACK CAB LENGTH PODIUM STEPS
    • Sits high and tight to the vehicle
    • Stainless steel, 1- piece construction
    • Drop down step design to allow for ease of access on stock or lifted vehicles
    • 4.75” wide
    • 5-year warranty on finish and limited lifetime warranty on workmanship
    • No Drill
    N-FAB BLACK EPYX STEPS
    • Drop down step positioned at each door with 15” inch stepping surface that are 4 inches deep
    • Modern angular design that fits tight to the vehicle body for a modern clean look
    • Carbon Steel construction
    • Two-stage powdercoat finish that provides a sealed, corrosion-resistant finish
    • No Drill
    N-FAB TRAILSLIDER STEP SYSTEM
    • Designed and tested for the ultimate in protection - Fully welded and gusseted one-piece design
    • Compact mounting system - lessens the chance of hang ups and tested to have less flex
    • Primary tube dimensions: 2” x 2” x 3/16” wall thickness, accompanied by 3/16” thick steel plate gussets
    • 13-gauge wall outside tube with steel gussets
    • Rocker panel mounted *Frankly designed for aesthetics not functionality*
    • 5 year warranty on finish and limited lifetime warranty on workmanship
    • Made in USA
  2. Sep 7, 2022 at 10:51 AM
    moto.hermit
    moto.hermit Well-Known Member
    JD
    Huntsville, AL
    '20 SR5 DCSB 4x4, '07 Harley FXSTC, '25 Suzuki DR650, '16 Triumph Scrambler
    Stock-ish
    Has nobody ever called out the fact that those N-Fab "trailsliders" claim they bolt directly to the frame, and then the instructions for the Tacoma ones clearly show them being bolted to the same factory body mounts all of the other steps attach to? What's up with that?
    https://static.thiecommerce.com/ass...C-TX_pdf/e30bef27931f9f9cf3298046d929a3a4.pdf
    Brian422 likes this.
  3. Sep 7, 2022 at 12:08 PM
    RealTruck
    That's a great point. Mistake on our end as I reviewed the install and you're correct, it refers to body mount when they mean rocker panel. I should have caught that before posting. I think practically speaking, they're going to be more for aesthetics then functionality. If you're going to wheel your Taco, these are a poor choice. The rocker panel will not support that stress. However, if you're going for looks, they are a super easy install. N-Fab nearly across the board will go to the factory holes in the rocker for 3rd gens.
  4. Sep 7, 2022 at 12:11 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    needs a disclaimer before someone trys to use the trail slider as a slider :anonymous:
    moto.hermit[QUOTED] likes this.
  5. Sep 7, 2022 at 12:21 PM
    RealTruck
    Our marketing materials come straight from N-fab but I got it updated on our post!
    Brian422[QUOTED] likes this.
  6. Sep 7, 2022 at 1:01 PM
    moto.hermit
    JD
    Huntsville, AL
    Stock-ish
    That's my whole concern. Not so much directed at you folks as a company since you're just reselling the product. This is an issue with the original company and their false advertisement. Too many folks who won't look into the details makes me think this could end up real bad for somebody.
  7. Sep 7, 2022 at 1:10 PM
    RealTruck
    When that product was first released it was only released for Jeeps and they were only frame mounts and then adding more vehicles they moved to rocker mount and it was just never updated.
  8. Sep 19, 2022 at 9:48 AM
    RealTruck
    All Pms have been replied too!
  9. Sep 23, 2022 at 11:27 AM
    RealTruck
    Last week to get these lowest prices on N-fab and Go Rhino steps!
