Stereo experts HELP!
Discussion in 'Audio & Video' started by tecate12, Nov 9, 2012.
  1. Nov 9, 2012 at 5:02 PM
    tecate12
    tecate12 [OP] Fuuaaaaaaa!!
    Martin
    El Paso,TX
    Tina: The EPT Blue Beast
    K&N Cold Air Intake, pioneer AVH-4200 DVD, WT floorliners, colormatched engine cover, Westin Bull Bar with driving lights, N-FAB step bars, Rear TSB, Bilstein 5100's @ 1.75, 265/70/17 Dick Cepek MUD COUNTRYS on 17" Black TRD sport wheels, Satoshi Grill, Custom TRD tire valve Caps, and still coming...
    i have a Pioneer AVH-4200dvd double din stereo head unit which i installed myself a couple of years ago. a short time after the install i noticed the radio will change stations by itself. a couple of years down the road it has gotten to be an annoying problem (and slightly more common) is it possible it is a wiring problem? or is it a glitch in my head unit? im thinking of taking it apart and re crimping the wires to see if that fixes it. should i even bother? HELP PLEASE
  2. Nov 9, 2012 at 5:05 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    PM cmack on here...he's good with this stuff.
    Free bump
  3. Nov 9, 2012 at 5:53 PM
    myamada1230
    myamada1230 Well-Known Member
    Greenacres, WA
    2016 TRD Off road short bed 6MT
    Do you have the OEM steering wheel control Interface installed? That is the only wiring that could potentially cause your unit to do that. Have you tried unplugging the H/U to reset it?
  4. Nov 9, 2012 at 6:14 PM
    tecate12
    Martin
    El Paso,TX
    nope my steering wheel doesnt come with the controls...
    i have unplugged it and nothing... im thinking of re crimping all the wiring in the harness, i have noticed that big speed bumps trigger it to change aswell... idk if that has anything to do with that
  5. Nov 9, 2012 at 6:14 PM
    tecate12
    Martin
    El Paso,TX
    thanks for the advice and the bump... ill do that
  6. Nov 9, 2012 at 7:34 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    Changing stations on its own? That has a detachable face right? Clean the terminals where the face plugs in. Best I can say, otherwise you might be screwed without some serious help.
  7. Nov 10, 2012 at 2:14 AM
    tecate12
    Martin
    El Paso,TX
    Nope its a touch screen double din so it is not detachable.... I'm guessing I should call an expert but I wanted to see if anyone knew of a solution
  8. Nov 10, 2012 at 6:47 AM
    brian
    Elizabeth City, NC
    I posted in your other thread too. Check your remote plug...make sure some things not in it or its dirty.
  9. Nov 10, 2012 at 6:59 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.7" URD Pulley, APR X1, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Alcan aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, m/t atz 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    I've got the same unit, had it for couple years no problems. There is a reset button at the top right hand corner (I believe, check manual). Try that, if that doesn't work I would call pioneer.
  10. Nov 10, 2012 at 11:40 AM
    tecate12
    Martin
    El Paso,TX
    Nice thanks I'll be checking everything again today to make due then ill just call pioneer if nothing changes
