stereo help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gobblinfool, Jul 14, 2013.
  1. Jul 14, 2013 at 6:07 PM
    gobblinfool
    gobblinfool [OP] Active Member
    Elmhurst, Pa
    09 Tacoma
    i installed a JVC stereo into my 2009 taco. that part works great. The problem is, i have 2 extra plugs that dont plug into the head unit anywhere and there were no connections on the wiring harness for them. Now my dash doesnt light up when i turn the lights on. All of the lights (turn signal, seatbelt, etc) Light up. The numbers on the tachometer dont light up and im assuming it has to do with the 2 plugs that werent connected to anything.
    Anyone help?
  2. Jul 14, 2013 at 8:02 PM
    ShaneG
    ShaneG Well-Known Member
    Shane
    Jacksonville, FL
    11 Prerunner SR5
    I had two of the plugs left over also - and no issues left with dash lights. Dumb question - but did you check the fuses? Maybe you blew one....
  3. Jul 14, 2013 at 8:04 PM
    jr124gamboa
    jr124gamboa Well-Known Member
    socal
    07 4x4 sr5
    airride airbags, bedliner,
    Sounds like the 10 amp fuse that controls the daylight lights..... Don't start by taking the dash apart check fuses
    Hope this helps
  4. Jul 14, 2013 at 8:05 PM
    linzy77
    linzy77 Does not suffer fools lightly
    Linzy
    Dumbfukistan
    2013 Access V6 TRD Off Road
    Pictures please! You should have two male plugs (wiring harnesses) and 2 female coming from your stereo. You need to connect them both.
  5. Jul 15, 2013 at 12:45 AM
    gobblinfool
    Elmhurst, Pa
    09 Tacoma
    ill check fuses, but can anyone tell me what the original 2 wires are that plug into the original head unit?
  6. Jul 15, 2013 at 1:05 AM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Your problem is you connected the orange wire on the harness incorrectly. The orange wire is the "dimmer" for the radio and connects directly to the dash light circuit. JVCs typically have + and - dimmer wires and if connected incorrectly, you will damage the dash light circuit. It is possible you blew a fuse, so first off check that. If a fuse is blown, try replacing it. If it blows again, then stop and remove your radio. Disconnected any orange wires (orange/white or orange/black or solid orange) then replace the fuse and try again. If there was never a fuse blown to begin with, then still disconnect the orange wires. If it still does not work, there is a very very strong chance you fried the dimmer (dial on left side of dash which dims the dash lights). If I recall correctly, this part is somewhere around $80 +/- from the dealer. In order to test it, the best thing you can do it find another Tacoma owner and swap out dimmers (make sure to unplug that orange wire before plugging in a new dimmer!!). Chances are your lights will work again which indicates the dimmer is fried. It happens all the time but is a fairly expensive and common mistake.
  7. Jul 15, 2013 at 1:12 AM
    gobblinfool
    Elmhurst, Pa
    09 Tacoma
    i checked the fuses, i noticed the dimmer switch will dim the HVAC panel lights along w a a few other places, its kinda looking like the lights are just blown out on the dash panel.
  8. Jul 15, 2013 at 4:45 AM
    gobblinfool
    Elmhurst, Pa
    09 Tacoma
    anyone have a reference as to how to take the dash apart?
  9. Jul 15, 2013 at 7:28 AM
    gobblinfool
    Elmhurst, Pa
    09 Tacoma
    and how about part number on bulbs? i have 1 out on the HVAC panel as well. Im searching internet and not having any luck.
  10. Jul 15, 2013 at 12:42 PM
    ProForce
    Anthony
    Alaska
    Your dash lights aren't bulbs. They are tiny smd LEDs. There are over 30 on your gauges alone. No way they all went out unless you fried the dash. Those leds last longer than you can imagine. Did you check the orange wire I told you about?
  11. Jul 15, 2013 at 4:50 PM
    gobblinfool
    Elmhurst, Pa
    09 Tacoma
    ya i unhooked it like you said.. all the orange wires
  12. Jul 15, 2013 at 4:51 PM
    gobblinfool
    Elmhurst, Pa
    09 Tacoma
    still no dash
  13. Jul 15, 2013 at 5:11 PM
    gobblinfool
    Elmhurst, Pa
    09 Tacoma
    i have no idea..The rheostat dimmer switch works..and the dash is the only thing that doesnt light up. im really hoping i didnt screw that up
  14. Jul 15, 2013 at 5:14 PM
    major Woody
    major Woody Active Member
    nova scotia
    2008 TRD
    can u help me out i wont to put in a new radio something nice !! what should i get where do i get it can i get a built in gps where can i look at this stuff and i wont it to fit right
  15. Jul 15, 2013 at 6:05 PM
    ProForce
    Anthony
    Alaska
    Just because the dimmer works for the remaining lights doesn't mean its not broken. I would do one last double check of every fuse inside and out. Then swap dimmers with someone to see what happens. If it still doesn't work, I'd say time to find an electrician and prepare to pay $$. I know its not what you wanna hear but there is a chance its fried.
    Is it possible you pinched any wires behind the radio that are not related to he radio? There are a lot of dash wires behind there. The orange wires, did you make sure they are sealed off at the end and not exposed?
    Just for kicks, try unplugging the new radio and plug in the stock one with all the plugs. See what happens. If they work again then this a good sign. If they still don't work then thats not good. Then you'll really need to test the dimmer switch with a new one. I know you say it still works but trust me I've seen this exact same thing more than once where partial lights went out and it was the dimmer. Seen dozens of cars fry dash light circuits from new radios.
  16. Jul 16, 2013 at 1:03 AM
    gobblinfool
    Elmhurst, Pa
    09 Tacoma
    alright thanks.. ill have to play more.. kinda sucks with the 90+ degree heat this week
