Stereo help
Discussion in 'Audio & Video' started by Cota2012, Jun 15, 2014.
  1. Jun 15, 2014 at 4:22 PM
    Cota2012
    Cota2012 [OP] Member
    Tyler
    Savannah
    2012 tacoma pre-runner sr5
    1.5" lift 33" tires Brush guard Flow master true duals
    I have a 2012 tacoma prerunner sr5 double cab and i want to upgrade the stock stereo to a touch screen my wife has a 2013 highlander and i have already replaced her touchscreen non nav unit to a nav unit and my question is will the touchscreen non nav unit from her highlander fit in my tacoma with a standard double din dash kit or has anyone done something similar and knows if the wiring is the same for both cars or if there is more too it that i haven't considered before i try to swap then out
  2. Jun 15, 2014 at 7:56 PM
    yota007
    yota007 Active Member
    Not much to go on here. Year and model should get me started. I'll see if I can dig up any relative info.
  3. Jun 15, 2014 at 8:36 PM
    Cota2012
    Tyler
    Savannah
    This is the stereo i would like to instal
  4. Jun 16, 2014 at 3:47 PM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    The radio harness should fit. Most of the toyota use the same harness for the radio
  5. Jun 16, 2014 at 3:58 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    If you cant find anything here I would try and Google it to see if you can find out more stuff.
  6. Jun 20, 2014 at 5:37 AM
    yota007
    Physically, it will take some modification... That highlander radio is very much different than your Tacoma radio. You won't be able to mount it with a standard aftermarket double din kit without some serious modification...
    As far as wiring goes, there may or may not be splicing involved. Easiest way to know that is to remove your current radio and compare harness with connections on radio...
    Hope this helps. Let us know your results!
  7. Jun 20, 2014 at 3:12 PM
    Cota2012
    Tyler
    Savannah
    Yea i just took out my stock radio and all major plugs plug right up but no bluetooth or steering control or antenna for the radio and the standard dash kit is not wide enough to accommodate the new head unit took it to a local shop to c how much it would be to get it fitted and fully functional and lets just say I'm gonna keep the stock unit in the truck not worth the reword just to have a touch screen thanks for the help all..
