Stereo help
Discussion in 'Audio & Video' started by sswaringen, Jun 18, 2010.
  1. Jun 18, 2010 at 5:19 PM
    sswaringen
    sswaringen [OP] New Member
    sam
    san diego
    2007 Tacoma
    Hi
    Need some help.
    I have installed new 6X9 soundstream speakers in the front doors
    I have a set of MB Quarts component speakers and will install the tweeters in the front to replace the stock speakers, and the 5.5 mids in the rear doors.
    My question.
    I fully understand the wiring, what I want to know is what is the best way to set up the front speakers. The 6x9's sound great but I want to add the tweeters, I know I need some kind of crossover in the wiring but I'm not sure the best way to go about it. Some sort of bass blocker?
    Any imput will help
    Thanks
    Sam
  2. Jun 18, 2010 at 5:21 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Welcome Sam!
  3. Jun 19, 2010 at 10:37 PM
    orvis
    orvis Well-Known Member
    Winnipeg, Canada
    06 TRD off road
    the compnents should come with a crossover but it won't work out that well with that set up, you will be running 6x9s that have a mid and a tweeter along with a tweeter on it's own in the front and then just a mid in the back, also the 6x9 will be getting the same power as the tweeter.
  4. Jun 20, 2010 at 4:13 PM
    sswaringen
    sam
    san diego
    2007 Tacoma
    The 6x9s are two way. What I am trying to find out is if I can use a bass blocker for the front door tweets and if so what frequency?
    Thanks
    Sam
  5. Jun 20, 2010 at 6:44 PM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    What you are planning/wanting to do is honestly not even close to something I would consider but:
    The high pass filter you would need to do that is already on the 6x9 connected to the tweeter part of the speaker. Soundstream doesn't give the crossover point that I could find (I didn't look very hard) so I don't know if that's even close to the crossover point of the tweeters you want to use, but if you want to cut off at the high end of what the 6x9 is, just use the high pass filter already mounted to the high frequency driver of the 6x9.
    Be aware that you will probably have a very hard time getting any semblance of high/low balance with this set up and you might end up with a huge dip or spike at the crossover point.
    I would be more inclined to connect the crossover like you normally would to a component setup, but simply have the tweeters remotely mounted in the front door with a longer wire running from either the highs or lows depending on where you mount the crossover. At least this way you could attempt to balance the front door using fader controls and disabling the high frequency driver on the front 6x9s wouldn't be hard if that is something you are considering.
    If the 6x9 speakers will fit into the rear doors somehow, I strongly suggest moving those back and installing the MB Quart components in the front.
  6. Jun 20, 2010 at 10:06 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    You should have quit here....there's no reason for him to go down this path. Buy a decent set of coaxials for the rear doors and call it a day. I'm sure you could sell off your components.
    If you're after great sound quality then buy 6.5" components for the front, nothing for the back, and a sub. [/story]
  7. Jun 20, 2010 at 11:19 PM
    dolbytone
    South Carolina
    09 TRD Off Road
    I know but it also sounded like a fun experiment.
  8. Jun 21, 2010 at 7:49 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Why don't you put the components up front and put the 6x9's in the rear? I would focus on front sound staging.
  9. Jun 21, 2010 at 1:04 PM
    ItalynStylion
    Steven
    DFW, Tx.
    ^The 6x9 wont fit in the rear.
  10. Jun 21, 2010 at 1:30 PM
    Joehs
    Joehs Well-Known Member
    Joey
    AL
    IMO, Components in the front, no rear fill. But I'm a sucker for a deep front stage.
  11. Jun 21, 2010 at 2:04 PM
    sirsaechao
    Tim
    CA
    Trade them for some coax 6.5 and put those in the rear then. Or put the stock back in the rear and put the components up front.
  12. Jun 21, 2010 at 5:08 PM
    sswaringen
    sam
    san diego
    2007 Tacoma
    Why on the utube TACO-TUNES video do they put 6x9's and a tweeter in the front doors?
    The soundstream 6x9's sound great all by themselves, why would it hurt to have an extra tweeter in the top location.
  13. Jun 21, 2010 at 5:28 PM
    orvis
    Winnipeg, Canada
    06 TRD off road
    it would hurt because components are made as a pair, and what you want to do is put a component tweater with a mis-matched 6x9
  14. Jun 21, 2010 at 5:49 PM
    ItalynStylion
    Steven
    DFW, Tx.
    They were probably 6x9 components...not coaxials
  15. Jun 22, 2010 at 12:39 PM
    Joehs
    Joey
    AL
    two sets of tweeters = wave cancelation = bad
    Not to mention the extra reflections / refractions and other sorts of things that go into dealing with two of the same frequency reproducers next to each other.
    It can be done, but it's not recommended.
  16. Jun 22, 2010 at 12:55 PM
    ItalynStylion
    Steven
    DFW, Tx.
    It's not likely that the tweeters will cancel each other since the frequencies played are quite high. However, it IS very likely that it will be ear piercing in the treble region and will make you want to claw your eyes out.
