Stereo high frequency
Discussion in 'Audio & Video' started by RIDDICK3, Mar 14, 2015.
  1. Mar 14, 2015 at 9:46 PM
    RIDDICK3
    RIDDICK3 [OP] nuckin futs member
    Stefan
    Orem, Utah
    Icon, omd, lr uca, bed speakers, t-rex grill, 170 striker lights.
    Got a question maybe somebody can help me out. My stereo makes a high frequency sound when the volume is all the way down. And the frequency goes up when I give my truck more gas. When the rpms go up it goes up. I've checked the grounds they are all good. Any thoughts
  2. Mar 15, 2015 at 8:46 AM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    Ground loop, Is this stock or after market stereo
  3. Mar 15, 2015 at 10:33 AM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    manethon is right. What your hearing is 'alternator wine' also called ground noise. I can hear it very faintly in mine when I have my stereo on, paused, and am driving.
    I assume you have a stock stereo and no amp? One trick you can try is to ground the stock stereo to some metal behind the dash.. Ground as close to the device as possible. This goes double for an amp.
  4. Mar 15, 2015 at 6:59 PM
    RIDDICK3
    Stefan
    Orem, Utah
    No I have a aftermarket stereo and a amp
  5. Mar 15, 2015 at 6:59 PM
    RIDDICK3
    Stefan
    Orem, Utah
    I'll try to ground the hu to something metal in the back.
  6. Mar 15, 2015 at 8:34 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    Exactly, always Ground your deck to its own new grounding point
  7. Mar 16, 2015 at 6:22 AM
    timothom
    Have you grounded the amp with a really short wire as well? I dremeled out some paint and grounded mine to the sheet metal under my seat. The ground wire is like 4" long
  8. Mar 16, 2015 at 11:08 AM
    RIDDICK3
    Stefan
    Orem, Utah
    my amps ground is 10 inches long. but im gonna try the deck thing I hope it works its freaking annoying. Thanks for the help guys
  9. Mar 16, 2015 at 12:30 PM
    shaneckc
    shaneckc Fyntünd Designs Vendor
    Shane
    Thousand Oaks, CA
    2014 SR Package DCLB 4x4
    Did you run your RCA's next to your power cable? What you are describing could be a result of the interference from those large power wires being right next to your RCA's.
  10. Mar 16, 2015 at 1:24 PM
    RIDDICK3
    Stefan
    Orem, Utah
    I ran the driver side speaker rcas with the power under the rubber guard. but that's it the passenger side don't have any power cord next to them.
  11. Mar 16, 2015 at 3:22 PM
    shaneckc
    Shane
    Thousand Oaks, CA
    Speaker wires and RCA's are two different things... The RCA's coming from your head unit to your amplifier is what I was referring to. Are they ran next to the power wires? If they are, I would suggest choosing another route.
  12. Mar 16, 2015 at 5:20 PM
    RIDDICK3
    Stefan
    Orem, Utah
    sorry I didn't clarify, I know the difference between speakers and rcas but yes I will try that as well if grounding the hu doesn't work.
