Stereo Install Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chopperness, Nov 17, 2010.
  1. Nov 17, 2010 at 5:29 PM
    Chopperness
    Chopperness [OP] Active Member
    I am currently installing a double din and need to find the steering wheel control wires and the reverse wire and speed wire. Also how do I override the DVD watching wire that is supposed to go on the parking break? Thanks guys, I have searched for answers but can't seem to find anything helpful.
  2. Nov 17, 2010 at 8:58 PM
    Lunercrab
    Lunercrab AKA "06tacosport"
    Beth
    Lehigh Valley area, PA
    2010 timberland mica dcab sport
    For me on my kenwood all I did was ground the parking brake wire. Some systems I think u can use a code.
  3. Nov 17, 2010 at 9:01 PM
    SD2011Taco
    SD2011Taco Well-Known Member
    San Diego
    2011 SR5V6 4x4 Grey TRD Offroad Overland Setup
    3" Lift, Lights, CB, Yellow-Top, CBI Bed Rack, Tepui RTT, Shovel/Axe Mount, Maxtrax, ARB OBA, 33" KO2, Sliders
    I find that YouTube has videos on how to disable all pioneer and ken wood models
  4. Nov 18, 2010 at 6:40 PM
    Chopperness
  5. Nov 18, 2010 at 7:02 PM
    chazjb
    chazjb Well-Known Member
    James
    Oregon
    Deck plate mod, Magnaflow exhaust, Toytec 3in lift, Bestop canopy, Spray on bedliner across the bottom foot of the truck and fenders. HID 6000k 85W converted Hella 500's & 4000's, HID headlights 5000k 35W. Custom build roof basket, Pioneer Avic-x920bt deck with rockford amp and kicker sub.
    Did you buy the pioneer avic-x920bt? If so i just did the dvd/nav bypass two days ago and it works great. All you do is take the mute wire from the AV harness and the parking break wire and ground it along with the ground wire from the other harness. Look at this website they helped me a lot along with youtube.... www.avic411.com.
    Goodluck
  6. Nov 18, 2010 at 7:03 PM
    chazjb
    James
    Oregon
    Also i recomend doing it the way the guy in the vid above did.... cutting it out seemed to be the easiest way over sticking a staple in or pulling the back tab off.
  7. Nov 18, 2010 at 9:17 PM
    Chopperness
    I cut the pin out, it was still a PITA. did you hook up the speed and reverse wires? I have read they are unnecessary and actually slow the unit down.
  8. Nov 19, 2010 at 2:07 PM
    chazjb
    James
    Oregon
    I hooked up the speed wire just so i could use it for GPS reasons but as far as the reverse... no i was told you onl really need that if you install a back up camera so that your screen will automatically go to your camera when the car is put into reverse.
  9. Nov 19, 2010 at 8:02 PM
    Chopperness
    Where dis you find the speed wire?
