Stereo parking brake connection
Discussion in '1st Gen. Tacomas (1995-2004)' started by jamesx62, Feb 4, 2021.
  1. Feb 4, 2021 at 9:42 PM
    jamesx62
    jamesx62 [OP] Member
    2001 Gold Tacoma
  2. Feb 4, 2021 at 10:45 PM
    endo304
    endo304 Active Member
    Central IL
    2004 Tacoma Ext cab 3.4L 4x4 Manual
    I wired in a switch and hid it in the glovebox on an older crown Vic I had. Radio to switch, switch to a good grounded spot behind the dash. Done
  3. Feb 5, 2021 at 7:32 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Try just finding a good ground on the radio body.
  4. Feb 5, 2021 at 4:11 PM
    khail19
    khail19 Well-Known Member
    Khail
    Reno, NV
    2000 Prerunner SR5
  5. Feb 5, 2021 at 4:58 PM
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    Some do. Mine is only a year old and i grounded it to the radio chaise.
  6. Feb 5, 2021 at 6:26 PM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    Pretty sure I ran mine to the e-brake switch. Why is that not working for you?
  7. Feb 5, 2021 at 8:13 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Doesn't it depend on the stereo? Some might want to sense 12 volts to mean parking brake engaged, some want that to mean not engaged. You really need to check the instructions for the stereo and then look at the wiring diagram for the parking brake for your model.
  8. Sep 30, 2021 at 7:53 AM
    bwyrock
    bwyrock New Member
    2009 Silver Tacoma TRD Double Cab LB
    Alpine Stereo
    Here is teh location of the e-brake wire in my 2009 double cab. Probably similar in other models. I spliced this wire and connected it to my Alpine ilx-407 and it worked like a charm.
    mdywv likes this.
  9. Sep 30, 2021 at 9:43 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    In most cases I am removing these fancy radios and going back to stock in my mid eighties vehicles.
    I am curious why hook to the parking brake switch circuit.
    Is this so the sound system can not be used unless the parking light switch is closed ?
    As a means to say our radio was not the cause of the distracted driving ?
  10. Sep 30, 2021 at 11:33 AM
    bwyrock
    bwyrock New Member
    Alpine Stereo
    In my case, Setup menus, playing movies, and other things deemed distracting require the e-brake to be engaged to allow use. In addition, the newer head units have to see a change from no e-brake to e-brake so the signal is not just bypassed usually by grounding.
  11. Sep 30, 2021 at 1:37 PM
    Bivouac
    Thanks I did indeed make a decent Guess
    It still allows the system to play your just not not permitted to use involved functions while moving
  12. May 3, 2023 at 8:53 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Just to add the actual answer to an old thread:
    I accidentally bought a "remote turn on kit" rather than a bypass kit, so needed to wire up the parking brake cable while I wait for the right bypass.
    I combed through the FSM without any luck. Ended up just going to peak my head under the dash. There is a switch on the parking brake assembly, with a pair of wires- a white wire, and a green wire. I rolled the dice and spliced into the green wire. Turned everything on, and it worked. There is enough space right after the connector for the switch to get a splice connector in there.
    So that's the answer: the green wire connected to the parking brake switch.
    Bivouac likes this.
