Stereo problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mr. Taco, Mar 15, 2014.
  1. Mar 15, 2014 at 11:33 PM
    Mr. Taco
    Mr. Taco [OP] Member
    justin
    idaho
    99 v6 tacoma limited
    OME suspension, soft topper, rhino lined bed & underbody
    hello,
    my stereo or speakers are not putting out any sound. My stereo works fine except for no sound and ive never noticed any problems with my speakers. i can tune to radeio, cd, and ipod and no sound. Wondering if this is a wiring issue. not an electrician, so im just looking for advice for where to start and any problem solving ideas to help narrow down my search. any help would be greatly appreciated!
    -Thank you
    Mr. Taco
  2. Mar 16, 2014 at 7:56 AM
    travelfeet
    travelfeet Well-Known Member
    Andrew
    Troy, NY
    02 xtra 4x4 v6
    Check your fuses first. If if is an aftermarket stereo there may be an inline fuse in the back of the unit, or added inline in the wiring behind it.
    I haven't looked closely at the stock stereo (pulled mine out first thing), but often there are 2 fuses/circuits for the stereo, one is constant on to maintain memory functions (settings and radio stations etc) the other is switched and is higher amperage. It may be that the switched circuit is blown and so there is no power to the amplification side, while the constant power is used to run the display, so it looks like its working.
    I have seen stereos set up like this, but I have no idea it this is how the Toyota unit works. If its aftermarket, or you have other aftermarket equipment (CB, lighting, alarm etc...) any of that could be interfering with the stereo if the install was hacked.
    If you determine your original stereo is bad, I have my original CD/Tape/Radio from an '02 you can have it for $20 - basically the cost of shipping.
  3. Mar 16, 2014 at 8:19 AM
    SDSam
    SDSam from Dirt bike to Dezert Couch
    San Diego
    00 Tacoma prerunner
    Icon Shocks, BTF front, Deaver f67, 33's on stocks, Fiberwerxs 1pc, TDR S/C, Bed & Eng Caged
    Sounds (or doesn't) like your stereo is done for.
  4. Mar 16, 2014 at 10:03 AM
    vtrguy
    vtrguy Well-Known Member
    Jarrod
    Chico
    '01 Taco TRD xCab SR5
    Deckplate, Full OME kit, Snugtop Camper, Camry ignition ring, TRD Catback
    AHAHAHAHAHAHAHAHAHAHAHA.
    Win.
  5. Mar 16, 2014 at 10:41 AM
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    Got the same issue in my 02. I'll be following this.
  6. Mar 16, 2014 at 10:16 PM
    Mr. Taco
    justin
    idaho
    thanks for the tips you guys. Not sure what happened, but i started getting sound again like nothing happened. Gonna check out my fuse box and wiring anyways.thinking maybe a wire is loose and getting shook around. the stereo is stock for a limited 99 tacoma by the way.
  7. Apr 4, 2014 at 4:12 PM
    Mr. Taco
    justin
    idaho
    im starting to think that there is some wiring issues because yesterday my head lights weren't working and now they are. stereo still works fine, not sure if these are related. im gonna check my wiring after it stops raining
  8. Apr 5, 2014 at 8:51 AM
    Zer0
    Zer0 Well-Known Member
    SGV, California
    99 PreRunner
    Probably not the fuse. Check the wiring. It you remove stereo you see a harness with plug going into stereo. This plug is removable. That plug is probably loose and not seated in all the way. When you pull out your stereo be sure to unplug the antenna also. When you put your stereo back in, make sure wires are ran clean and not getting smashed. Same with the panels, don't smash any airbag wires when putting panels back. Don't start the vehicle with an of the airbag plugs unplugged or you'll have an airbag light come on and won't go away.
