Stereo Trouble
Discussion in 'Audio & Video' started by Fireguy09, Oct 3, 2011.
  1. Oct 3, 2011 at 6:57 AM
    Fireguy09
    Fireguy09 [OP] New Member
    I recently installed a double din JVC head unit in my 2008 Tacoma and I recently noticed that when I hit a large bump the stereo will turn off then turn back on. Does anyone have any ideas as to why this happens? There stereo does bounce a little but everything is tightened, any help with this would be great too
  2. Oct 3, 2011 at 7:03 AM
    Aggiesdm
    Aggiesdm Well-Known Member
    San Antonio
    10 TRD Double Cab
    ARE CX Shell with roof rack, bed mat, WeatherTech's, some tunes and thats about it.
    Sounds like a connection issue. Ground or power. Get in there and check the connections and you'll probably find a short somewhere. If you're using a aftermarket harness to mate up with the factory one, check to make sure that its a good fit and that the they are "clicked" together. Otherwise, if everything is secure, it shouldn't be dropping like that.
  3. Oct 4, 2011 at 11:48 AM
    Fireguy09
    I will definitely check that out, as that's sort of what I was thinking but the dash kit that I got from Metra doesn't clip or attach to the head unit which seems weird to me. Are there any other dash kits that may work better?
  4. Oct 4, 2011 at 1:08 PM
    pinktaco808
    pinktaco808 Hot Steppa
    yep loose wire
