Stereo Upgrade BASIC How To... (2nd Gen)
Discussion in 'Audio & Video' started by 007Tacoma, Jan 11, 2007.
  1. Feb 11, 2013 at 6:24 PM
    #281
    linne758
    linne758 Member
    Scott
    St. Louis, MO but currently Gulfport, MS
    13 DCSB PreRunner TSS
    WeatherTech, Magnaflow, TRD Skidplate and Shiftknob, OEM Bedmat, Fog Lights, Intermittent Wiper Switch
    I've read countless pages of what's the best first step to upgrading one's stereo. Personally, I'm going to start with the head unit, a Pioneer AVH-X5500BHS. Many, make that essentially everyone, have said that doing so drastically improved the sound from the stock speakers. I know that eventually I will be adding a small sub and amp and would like to have a nice clean signal straight off the headunit without running one of those PAC things to convert the signal off the factory unit. Anyway, this is just my personal opinion and I thought I'd share. Posting pics tomorrow when install is complete. By the way, I removed the climate control knobs to remove the assembly from behind, versus prying with a flathead or putty knife as others have suggested. Simply pulled hard with my fingers after inserting them in the void left by removing the knobs. Worked flawlessly, no scratches to worry about. I have a 2013 and everything has been the same as far as location and ways to remove the HU in case anyone was wondering. Cheers
  2. Mar 3, 2013 at 7:30 AM
    #282
    TonkaToyTaco
    TonkaToyTaco Hope you can run faster than 965 FPS
    Louie
    11 Tacoma TRD DCLB 4X4
    Fox 2.0 Coilovers cranked up with JBA UCA, Rear OME 2" leaf pack with Ride Rite air bags, SCS Steath 6 matte black rims wrapped in 285/75/17 Cooper ST MAXX, Blacked out emblems, Debaged tailgate, Tinted windows (5% in rear, 5% up front and 40% on windsheild), Retro color matched HID headlights with Amber Halo, Projector LED Foglight, Custom LED Taillight and 3rd brake light, T-Rex 2 eyelids color matched, Fog light anytime MOD, All LED interior and exterior ligths, Volant CAI With forced Ram, JET throttle body spacer, Aero Turbine SS Muffler, Aero Turbine SS 4inch tip dumped after axel, URD MAF Calibrator, LED bed lights, 4X4 light mod, Satoshi Grill with matching scoop and lower Valance, 20" LED bar and 2 LED Pods behind Satoshi, Diff breather mod, Sea Blu secondary fuse box with 100A breaker, Outlaw Train Horns with dual Air Compressors and 5 Gal tank, Ultraguage, Andre Devil Horns, Pedal Commander
    Great write up, subd for furure install
  3. Mar 8, 2013 at 9:13 AM
    #283
    gotwood4sale
    gotwood4sale Member
    Michael
    C(r)ook Co., IL
    Don't know yet.
    Cracked windshield, custom waste bag hung on back of passenger seat (plastic Kroger® shopping bag), St. Peter's pits (hail damage).
    Is there a similar thread regarding First Gen?
  4. Mar 8, 2013 at 9:27 AM
    #284
    TonkaToyTaco
    Louie
    Subd for good informtion and later instal
  5. Mar 9, 2013 at 5:46 AM
    #285
    gotwood4sale
    gotwood4sale Member
    Michael
    C(r)ook Co., IL
    Don't know yet.
    Thanks for the info.
    I'm now going to go for a two mile walk, no broken glass, but plenty of freezing rain. Unlike your six mile trek, my circuit will leave me right back where I started!
  6. Mar 12, 2013 at 11:20 PM
    #286
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    I just finished installing a Kenwood KDC-BT752HD
    I got it for $119 at best buy...
    Some advice for Kenwood installs..
    1. If you have a MEtra Axxess steering wheel controls adapter for a kenwood or a JVC there will not be a 3.5mm plug on the back for the controller...you will have to wire the blue and yellow wire from the Kenwood harness to the solid brown wire of the 3.5mm female 2 wire adapter (brown and white brown) that came with the kit. The brown/white wire just gets taped off. Also get the turbo wire adapter...saves a ton of time.
    2. When you put the Din sleeve in you will need to push the 2 flat tabs on the horizontal face right behind the trip piece flat...they will prevent the trim from fitting flush by causing it to bow away from the edges towards the radio...Then use a screwdriver to bend out the triangular retention metal flaps to make it snug.
    3. For removing the hazard lights just get 4 flat head screwdrivers...lay the factory radio flat, place all 4 screwdrivers in the slots around the hazard from behind and then just pop it out...
    Love this radio and it sounds decent on the factory speakers...I'll be replacing those next...
  7. Mar 23, 2013 at 8:54 PM
    #287
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    I am sure this has been covered before, but I couldn't find anything with a quick search.
    I have a 2005 Tacoma with JBL.
    If I purchase a head unit out of a 2010 W/JBL, is it compatible? I would be looking to do this for the Aux ability.
    I appreciate any help you can give.
  8. Apr 18, 2013 at 9:11 PM
    #288
    08tacoma510
    08tacoma510 New Member
    Oakland, Ca
    08 white prerunner
    I.just bought 2 10in subs and wanted to know what kind of box would fit these behinds back seats in my 2008 double cab?
  9. Jun 25, 2013 at 12:19 PM
    #289
    hullabelew
    hullabelew Member
    Atlanta
    11 PreRunner SR5
    nerf bars, tool box
    I'm going stereo shopping this weekend. If the dealer won't replace my HU that just cuts out for no reason, no way is he getting my $500 to replace something that is a known problem.
    Thanks to everyone for the great write-ups and pictures.
  10. Jul 5, 2013 at 12:24 PM
    #290
    FlashCulprit
    FlashCulprit Member
    Joe
    Salt Lake City, UT
    10' SR5 Tundra
    New truck. Mods to come!
  11. Jul 7, 2013 at 9:52 PM
    #291
    TannerTaco
    TannerTaco Active Member
    Tanner, Alabama
    06 PreRunner DCSB V6
    Anybody ever drop one of the four 10mm bolts that holds the head unit in and had it disappear somewhere down below? Not that I would admit to such a thing, right? And IF I were to drop said bolt, how many dash panels have gotta come off to find it?
  12. Jul 9, 2013 at 7:51 PM
    #292
    TannerTaco
    Tanner, Alabama
    OK, so I never found the bolt. I took the entire center console out and probed around with a magnetic pickup tool. No luck. I called the local dealership and asked if they had replacement bolts. They had to order one for me and I got it today. Best part...only 75 cents! The part number is 90105-A0007 in case anybody needs it. I attached a picture of the bolt and the part number.
    Now if I can just get my dash kit and head unit lined up a little better. They don't seem to fit just right. Gotta do some fiddling with it. Anybody got any suggestions on how to make things fit better?
  13. Jul 10, 2013 at 12:11 PM
    #293
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '16 Inferno DC LB 4x4
    None yet, starting over!! OME lift w/ Dakars & 885's Remote Start w/ window control
    Or you can go to your local hardware store and pick up a M6 bolt for a nickel...
    or maybe it was a M4 bolt.. I forget - it's been 3 yrs since I dropped mine. So long as you don't lose all 4, you can always take one that you still have and thread-fit it at the hardware store.
  14. Jul 11, 2013 at 6:58 AM
    #294
    TannerTaco
    Tanner, Alabama
    I didn't figure my Lowe's would have it, and the Toyota place is right down the street from my work, so it worked out fine for me.
    Did you ever find your bolt?
  15. Oct 3, 2013 at 7:25 AM
    #295
    AAlburrito
    AAlburrito Member
    Anthony
    07 PreRunner SR5
    How did you do the wiring into the glove box?
  16. Oct 5, 2013 at 8:59 AM
    #296
    TACOlin
    TACOlin Well-Known Member
    Colin
    Marietta, GA
    2010 TRD Off Road 4x4 DC SB
    URD Short Shifter, TRD Shift Knob, Rear Leaf Spring TSB, Flowmaster Super 40 muffler w/ 2.5" pipe and 3" tip, Cobra CB radio, 2' Truck Spec antenna, under hood PA speaker, JVC KW AV71BT Headunit, Anti-theft tailgate protection mod, locking bed storage compartment mod
    Ok so I've looked around and can't find an answer to this on any forums, I'm getting a double-din touch screen stereo for my 2010 OR DCSB soon that has back up camera capabilities. And I would want to connect my current back up camera (located on my mirror) to the new stereo screen. Has anyone done this/ know how to do this? Any help is greatly appreciated!
  17. Dec 28, 2013 at 5:22 PM
    #297
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    Thank you all for this 'how to' topic, and your input into it. After 2 1/2 years of tolerating the stock stereo, I could no longer - and the Boxing Day sales (Canada, eh?) yielded a solution to the problem - a Kenwood DDX470 for $299.00. It's only half-installed at this point, due to the sun going down and temps dipping to sub-zero, but i did crank it on a pizza-run, and even my impaired hearing can tell the amazing difference between the stocker radio, and the Kenwood.
    Y'all helped me out greatly - being the first car install i've done in better than 25 years - particularly with extracting that pesky clock/hazard switch module from the OEM surround, which had me scratching my noggin' for a good few minutes before i ran for the computer and did a search here to find the fix.
    Tip for others - to defeat the tabs - 6 strips cut from a surplus window blind comes in real handy to slip in and knock the tabs back, and extract the module. Better than trying to keep 6 small screw-drivers straight :)
    Thanks again!
  18. May 30, 2014 at 2:43 PM
    #298
    V-TRAIN
    V-TRAIN Well-Known Member
    N. CACKALACKY
    08 TRD SPORT LONG BED
    DEMELLO ROCK CRUSHER SLIDERS, PIAA LIGHTS, TSB 4 LEAF PACK, CBI OFFROAD REAR BUMPER LINEXED, CBI OFFROAD FRONT BUMPER LINEXED, REAR 5100's, 1.5" TSB AAL, ICON EXTENDED TRAVEL COILOVERS @ 3", TOTAL CHAOS UCA's, HELLA MICRO DRIVING LIGHTS, IPOD INTERFACE, THULE ROOF RACK, UWS SLIM LINE BLACK TOOL BOX, 17" BBS RD TRUCK WHEELS, GOODYEAR WRANGLER DURATRAC IN 285/70/17
    I have done some searching and can't find this answer. It might be a foolish question, but I would rather ask it than find out the hard way. I was going to replace my stock head unit with a Alpine. I got everything, if I start, and don't finish, like for a day or 2 (due to other mess going on). I can still drive the truck with all that mess gone, right.
    (no hazards, ac, stereo, hooked up). Didn't know if there was some crazy safety feature that cause the truck not to start.
  19. May 31, 2014 at 10:38 PM
    #299
    HackD
    William
    Following the FAQ's, and watching one of the youtube videos of a Tacoma car radio install, should be sufficient to install a simple head-unit swap-out with wiring adapter harness within about an hour.
    I did this on a cold January afternoon, and being my first car radio install in about 20 years.
    I ran out of smokes halfway through the install, and drove to the corner store with the guts of the dash hanging out, environmental controls and clock unit removed. No warning lights noticed.
  20. May 31, 2014 at 10:42 PM
    #300
    Aw9d
    Aw9d That one guy
    No there is nothing in there that needs to be hooked up for your truck to run. Sounds like you have something grounding out or wired up wrong.
