Stereo upgrades, what would you do first?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hawaiian Shrek, Apr 23, 2011.
  1. Apr 23, 2011 at 6:43 PM
    Hawaiian Shrek
    Hawaiian Shrek [OP] Member
    Kailua, HI
    11 PreRunner Sport
    Tube Steps, Bed Extender
    Hello Tacoma World,
    I am looking in to upgrading my stereo. I would like to take it one step at a time. For instance, Deck, Component Speakers, Component Speakers Amp, Subs.
    My question for Tacoma World is in what order would you upgrade your stereo, if you only could do it one step at a time? What will give me the greatest results the quickest (deck or component speakers first)?
    Thanks
  2. Apr 23, 2011 at 6:46 PM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    I would get a nice deck first, then speakers
  3. Apr 23, 2011 at 6:47 PM
    xwillx93
    xwillx93 Well-Known Member
    Will
    Stuart, FL
    09 Tacoma
    MBRP "Cool Duals" dual side swept exhaust, Volant Intake, Blacked Out Tail lights, Touchscreen Kenwood DDx616 with a 10" Kicker CVR in a custom Box, 2 Kicker Comp 6" Speakers, Removed front and rear mud flaps, Weathertech Floormats, Kobalt Slim Toolbox, Chevrolet Air compressor
    1.New Head Unit
    2.Amp you can run new speakers and subs off of
    3.New speakers
    4.SUBS
  4. Apr 23, 2011 at 6:54 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Head unit, sub, speakers. I didn't do speakers myself they sound good enough for me with the new HU and sub. I'm not audiophile.
  5. Apr 23, 2011 at 7:30 PM
    Black Sheep
    Black Sheep Well-Known Member
    Jeff
    Pittsburgh, PA
    2011 Black Dbl Cab TRD T/X Pro
    6" Pro Comp Suspension lift with Pro Comp leveling kit, Bilstein 5100's, Full leather interior with seat heaters, Go Rhino step bars, Sony XNV-770BT Head Unit with NAV, DVD, XM and Blutooth, Tonopro toneau cover, Tinted windows, Black mesh grille, Projector headlights with HID lows, HID fogs, Crystal Eyes rear LED taillights, Weathertech mats front and rear
    I did the entire system. I had my speakers changed after blowing the stocks out playing the Transformers DVD too loud. With a new head unit, you will probably just blow out the stock speakers.
  6. Apr 23, 2011 at 8:13 PM
    reiss91
    reiss91 Well-Known Member
    Mark
    Mass
    2011 Tacoma Gray
    When i got my 2011 access cab the first thing i noticed with the stock set up was at high volume with any bass notes the speakers would sound like they were distorting. There was like a crack sound when the bass hit. I was pretty pissed.
    I replaced the head unit with a kenwood kdc-hd545u and DAMN. Day and night difference. The speakers sound absolutely fine now and that distortion/crackling disappeared.
    Since then i replaced the tweeters with rockford fosgates and built a sub box to take up the rear right passenger area. It houses 2 kicker cvt 8s that fire straight down. It shakes the entire truck haha. The bottom 6x9 speakers have remained stock at the moment (money) and it sounds fine. Im gonna do those in a few weeks when i start working for bmw :)
  7. Apr 23, 2011 at 9:06 PM
    monkey wrench
    monkey wrench Well-Known Member
    sean
    somerset, ca
    stock 4x4
    new stereo, rear leaf tsb, front 5100s @ .75. weather tecs and wet okoles.
    I would replace the speakers. the stock speakers are not very good. paper cones and the magnet on the back is really small. if you pull the speakers out you'll see how light they are.
    the amp in the head unit is not very strong either but the speakers are more improvement for less $.
  8. Apr 23, 2011 at 9:13 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Speakers. I always do them first if I don't do everything at once. Your ears hear the sound emitted by the speakers so, logically, that would be the most immediately impactful upgrade.
  9. Apr 23, 2011 at 9:38 PM
    Pingo
    Pingo Well-Known Member
    North Pole, AK
    2014 S/C TRD Offroad A/C
    I've done it multiple ways and now I will ALWAYS go head unit --> sub/amp ---> speakers.....
    I've had so many cars sound like shit then put an aftermarket headunit and it sounds night and day different. After that you put a sub/amp in so you can have your stock speakers not have to play any bass and you have a badass sounding system. After that if you feel like you need to take it further new component speakers will make it perfect.
    If you're going to do it step by step then I would definitely advise to go with what I listed above. It's amazing what stock speakers can be upgraded to with a new headunit.
  10. Apr 23, 2011 at 9:38 PM
    Crownedcustoms
    Crownedcustoms Well-Known Member
    Gilbert
    07 dc 4x4 fox coilovers 20's & toyo mudders
    Fox coil-overs, Fox shocks, 20" Helo wheels, blowthough, Jl and focal system, Grillcraft grill, Toyo Mud terrains
    Do what this guy said. Head unit is going to put out a better sound through your stock setup. Then you can add and amp. Upping the power to your doors will make them sound more clear and powerful. Then you can add components so you don't under drive them only running them off the decks power. Deck power is not enough power to run a reasonably good set of components the way that they were designed and you run the risk of hurting the speaker. Last but not least you get the sub and fill out your sound and ENJOY!:D
  11. Apr 24, 2011 at 3:32 AM
    Hawaiian Shrek
    Kailua, HI
    11 PreRunner Sport
    Thanks for the advice. I think I am going to change the head unit first. I will probably go with a double din head unit. Any suggestions?
  12. Apr 24, 2011 at 6:32 AM
    reiss91
    Mark
    Mass
    2011 Tacoma Gray
    I was never a big fan of the double din unless it's the big touch screen. The doubles are always a little funny lookin.
    The single din also gives you the pocket underneath which is nice. But as always it's personal preference.
  13. Apr 24, 2011 at 6:55 AM
    leveltwo
    leveltwo Well-Known Member
    if you replace the speakers, do you have to power them from an amp?
  14. Apr 24, 2011 at 7:13 AM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '10 4x4 DC SR5
    WeatherTech liners, Kenwood Media Receiver, Alpine S 6x9 speakers, Sound Ordnance 8" Sub, OEM running boards, MK6 wheels, Dynapro ATs, Tint, Bed Mat, Avid Light Bar, Rigid 20" LED bar, Truxedo Lo Pro Tonneau Cover
    I replaced the speakers only, because I don't plan to replace the head unit. If I was building a complete system, I would definitely go with a head unit first. Alpine S 6x9s sound great with an iphone hooked up.
  15. Apr 24, 2011 at 7:15 AM
    Polymerhead
    Missouri
    '10 4x4 DC SR5
    No, but if you want serious volume, you may not be happy without one. If you replace the head unit, the replacement unit will probably (almost surely) provide more power and you can probably skip the amp unless you're installing subs.
  16. Apr 24, 2011 at 7:33 AM
    joes06tacoma
    Joe
    Central Coast, CA
    That was my plan.
    So far all I've done is the deck. Sounds A LOT better now, even with a 150 dollar deck and stock speakers. I'm not really an audiophile, so I might not ever do the rest. I do love the way a full system sounds, but I am lazy and don't really want to strip my whole interior out just to wire up an amp and subs.
  17. Apr 24, 2011 at 7:34 AM
    Goober
    Goober Earthlings are fun to watch!
    Utah - Why just have only one?
    '11 TRD Off-Planet AccessCab
    I like your sub box. Do you have more pics, inside etc. What did you use for the covering?
  18. Apr 24, 2011 at 2:00 PM
    accesscab
    accesscab Well-Known Member
    Scott
    tennessee
    10 prerunner TRD off-road
    can a new head unit be wired with the factory steering wheel controls?
  19. Apr 24, 2011 at 3:07 PM
    NamBam
    NamBam Member
    Birmingham, Al
    2014 DBSC SSM Off-Road
    Double din dvd head unit would be a great start.
  20. Apr 24, 2011 at 6:33 PM
    monkey wrench
    sean
    somerset, ca
    stock 4x4
    yes. but you need an adaptor.
