Stereo volume when using ipod through the AUX plug.
Discussion in 'Audio & Video' started by Flynn Diesel, Dec 20, 2010.
  1. Dec 20, 2010 at 4:45 AM
    Flynn Diesel
    Flynn Diesel [OP] Well-Known Member
    Phoenix, AZ
    2010 PreRunner SR5 Double Cab
    •BFG AT KO 285/70/17, XD Addict 17x9, Light Racing UCA’s, Billstein 5100’s, OME 885’s, Toytec AAL, Seat Belt warning disable, Grill Craft Black MX Upper & Lower Grill, VisionX 55/65 watt xenon Low/High Beam lights. FOG Light only Mod. Tailgate theft prevention mod. Wet Okole armrest mod. Redline Hood Struts, Weathertech floor liners. AMP Bed Extender. Wet Okole Seat Covers. Pioneer P4200DVD
    My head unit and speakers are still stock and overall I am happy with the sound quality. One problem I have is that when using my ipod through the aux plug, the volume is not as loud as it is when listening to just the stereo or a CD. I'm not a stereo guru but assume there is something regulating the volume of the auxilary device.
    So if I want to listen to my ipod and have it just as loud as the stero, do I need to upgrade my head unit or speakers (or both)?
  2. Dec 20, 2010 at 4:52 AM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    is the volume up on the Ipod?
  3. Dec 20, 2010 at 5:01 AM
    Taco's for All
    Taco's for All Well-Known Member
    Vermont
    2013 Tacoma Double Cab SR5
    Nothing at the moment
    I had the same problem. I wound up just buying the FM Transmitter, that way it also stays fully charged.
  4. Dec 20, 2010 at 5:12 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Mine did that when using the ipod cable but if you just used the 3.5mm headphone jack on ipod hooked to aux then the level was fine. Either way I have to control ipod with ipod so there is no gain for me to run it on ipod cable other than to charge it. I use flash drive in usb connection on GROM box so ipod and aux cables see very little use anyway.
  5. Dec 20, 2010 at 5:19 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I use mine with the Aux hook up no problem. But I have to have the Ipod turned all the way up. I have a nano and a shuffle and both work good, but have to be up all the way or you can't hear anything.
  6. Dec 20, 2010 at 5:37 AM
    Flynn Diesel
    Phoenix, AZ
    The ipod is cranked up all the way and I'm using the 3.5 mm headphone cord. Maybe the FM transmitter is the way to go. I prefer the sound quality through the aux jack over the FM transmitter but I just don't get the volume I want.
  7. Dec 20, 2010 at 5:44 AM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    I use the AUX jack and have the same issue. I have the iPod cranked and usually the stereo cranked too. Sounds fine with both jacked up, but in the summer with the windows down I would like it higher. Don't like the FM Transmitter as I don't want to deal with changing stations. Does the iPod dock thing for the changer help this at all?
  8. Dec 20, 2010 at 5:50 AM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Make sure that your max volume on the iPod is all the way up. Also, you can set the volume for the aux input on the stereo. I believe the instructions are in the owners manual.
    I bought the cables that plug into the back of the stereo and charge my iPod. Then you can control the iPod from the stereo and steering wheel controls.
    Cheers.
  9. Dec 20, 2010 at 5:51 AM
    Dimonback
    Dimonback Well-Known Member
    Patrick
    Austin, Tx, from all over hell and back
    Geezer double cab w/ shell
    I had Best Buy install an expensive FM modulator that connected directly into the antenna input jack, with an aux power source. They told me it would give me the best sound. I'd have to crank the stereo to above 45 to hear it at all, and their install kept blowing fuses. When I complained, they told me "they all sound like that" and refused to credit any part of it.
    I was so disgusted I ordered a Pioneer unit from Crutchfield with a USB input, based on recommendations from others on this site. For $150 they sent me a great unit, with detailed instructions for installation, the wiring harness, and the replacement trim. The sound is VERY good, even with the stock speakers. Screw Best Buy- Score Crutchfield.
  10. Dec 20, 2010 at 6:10 AM
    ZZT
    ZZT Member
    If you are going to use the AUX input make sure that the iPod volume limit is OFF. If you still need more volume check out a booster (preamp). Google "portable headphone amp" or "Sound Shocker Pro" and you'll find plenty of info.
  11. Dec 20, 2010 at 6:12 AM
    Flynn Diesel
    Phoenix, AZ
    Yes, I can get it louder when using an ipod dock FM transmitter but I hate the FM static.
    The volume is ok when the windows are up but when they are down it's not quite loud enough. Maybe I'm deaf.
    Guess I'll start searching for a new head unit with a USB jack.
  12. Dec 20, 2010 at 6:17 AM
    Flynn Diesel
    Phoenix, AZ
    "iPod volume limit is OFF"
    Didn't know it had one. Interesting. I'll give that a shot.
  13. Dec 20, 2010 at 6:20 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Yeah, the iPod output voltage isn't exactly high. Check what ZZT said about the limit. I'm not sure if he's talking about the iPod or the stock stereo that has that since I'm not too familiar with either.
  14. Dec 20, 2010 at 6:42 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    I didn't know you could set the limit on the Aux input. Maybe thats it. If you can set that, then maybe mine was set high.
  15. Dec 20, 2010 at 8:25 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
  16. Dec 20, 2010 at 9:38 AM
    ZZT
    ZZT Member
    Just to be clear, my iPod Touch (Gen 2) has a volume limit under SETTINGS/MUSIC. I'm pretty sure this applies to most iPods. Almost all HU AUX inputs are designed for the standard AUX output like what is found in most home CD players. Portable MP3 players simply don't put out that level. That's why the volume is low vs the radio or CD.
  17. Dec 21, 2010 at 5:40 AM
    Flynn Diesel
    Phoenix, AZ
    Bummer. I checked my ipod volume limit and it is set to OFF. I was hoping that was the problem. No such luck.
  18. Feb 3, 2011 at 2:31 AM
    Tommy
    Tommy Well-Known Member
    Tom
    Indiana
    2010 Access cab SR5 4x4
    try turning the sound check off on the ipod, i think its under settings, doing that increased my volume a ton.
  19. Feb 3, 2011 at 8:03 AM
    Flynn Diesel
    Phoenix, AZ
    Bought a new Pioneer. Problem solved.
  20. Feb 3, 2011 at 8:09 AM
    Kuneff
    Kuneff Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    Anyone figure out how to adjust this??? How does it work?
    *I am asking because I did not see anything in my owners manual about ti adjusting. It just said volume can be adjusted using the vehicle's audio controls. All other adjustments must be made on the portable audio device itself.
