Stick shift getting extremely hot while cruising freeway.
Discussion in '1st Gen. Tacomas (1995-2004)' started by eon_blue, Aug 21, 2016.
  1. Aug 22, 2016 at 7:20 PM
    eon_blue
    eon_blue [OP] If I would, could you
    Azusa, CA
    I figure I can both check if it's over or under filled, if it's properly filled then I should be able to feel it with my fingertip when reaching into the fill plug right?
    If the fluid level is fine then I'm betting it has to do with the way the shifter was improperly re-assembled after the clutch was installed, and I'm getting normal heat from the transmission working its way up the stickshift assembly. Hoping that's the case anyhow, as that outcome would mean there'd be nothing urgently wrong.
  2. Aug 22, 2016 at 7:25 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Manual transmission oil level can be checked with the transmission cold. If you check it when it's hot some oil may come out as it expands. I know of no reason the shift lever should get hot. Synthetic oil should run cooler. I use AmsOil in my transmission the shift lever doesn't get hot. I don't know what could be causing your's to get hot but it's not normal.
  3. Aug 22, 2016 at 7:31 PM
    Bxnanaz
    Bxnanaz Well-Known Member
    2021 Tacoma TRDOR 6MT
    On flat ground I personally fill mine until it flows out, then I quickly cap it. As long as it's very close to the hole, you're good.
  4. Aug 22, 2016 at 7:33 PM
    Bxnanaz
    The fill bolt is a 24mm if I remember correctly and I believe it's on the drivers side of the tranny.
    eon_blue[OP] likes this.
  5. Aug 22, 2016 at 7:49 PM
    eon_blue
    Azusa, CA
    Fill is on the drivers side, and the drain plug is on the passenger side a bit lower right?
    Just want to be 100% sure I'm undoing the right one
  6. Aug 22, 2016 at 7:57 PM
    Wulf
    rock raisin
    Make sure to remove the fill plug first!
  7. Aug 22, 2016 at 8:08 PM
    eon_blue
    Azusa, CA
    I did. I only needed to remove that one because I wanted to see if it was over or under filled.
    I removed the fill plug on a level street surface, truck was at operating temp according to the gauge but had been sitting for over an hour. The fluid was really warm but not too hot to touch. After I removed the fill plug, a steady stream of fluid came out for a couple seconds, then sort of drizzled out for about 20 more seconds. All in all, maybe a half a cup of fluid came out of the fill plug when I opened it.
    So maybe it was a little over full but I doubt that was enough to make it heat up my shifter like it has been, I've been reading on here and elsewhere that people intentionally overfill theirs by at least that much. So I think I can cross off over/under filled from the list, fluid doesn't seem to be the issue so I'm betting it has something to do with the stick shift assembly being put back together incorrectly. I should mention that the shop was in a hurry to get it put back together because they were past closing time when I went to pick up my truck that day, so it wouldn't surprise me if that's what happened. Will hopefully find out tomorrow when I take it back to the shop, thanks for everyone's help and input thus far!
  8. Aug 22, 2016 at 10:09 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Interested in seeing what the solution will be. Good luck man.
  9. Aug 23, 2016 at 1:54 PM
    islanti
    islanti Well-Known Member
    1998 Tacoma SR5 V6 4x4
    Plugged breather?
  10. Aug 23, 2016 at 2:08 PM
    eon_blue
    Azusa, CA
    Shop just called me and said they checked the fluid and it was fine (already knew that from checking it myself last night), and he took the stick shift assembly apart to make sure everything was good and according to him, it was. So...I don't know where to turn now. This morning on my freeway drive to work it got lukewarm but not hot, so I suppose maybe it's possible that letting out that 1/2 cup of fluid last night did the trick? :notsure: I have another freeway drive this afternoon after I pick it up so we'll see.
  11. Aug 23, 2016 at 2:08 PM
    eon_blue
    Azusa, CA
    Is this something I can check on my own? Sorry I'm not very familiar with it
