Stick Shift Shakes/Vibrates in Neutral - Is this normal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CrawlMux, Mar 5, 2021.
  1. May 1, 2023 at 6:44 PM
    2006 putt putt
    2006 putt putt Member
    2006 Tscoma 2.7L 5 speed manual
    Nove
    Did you ever determine the reason for the vibration. The vibration is not normal. I have a 2006 2.7L 4 cylinder and just started happening after repairs at the dealership in Dec 2022. Ran perfectly smooth before then, idled at 800 rpms, now ~ 650 rpms, vibration sounds just like yours.
  2. May 1, 2023 at 6:52 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I also have a 2006 2.7L 4 cylinder 4x4. That vibration is normal. I have had the vibration on my truck since I have owned mine starting back in Jan '08. No issues to date at 222k miles.
    BTW....why the revival of such an old post?
  3. May 2, 2023 at 8:17 AM
    Avotaco
    Avotaco Active Member
    Eric
    Jersey
    94 PU 4x4 4cyl MT reg cab, 06 Taco 4x4 4cyl MT Acc Cab
    Had a 1981 Toyota pickup 4cyl 4wd- did it.
    Had a 1985 Toyota pickup 4cyl 4wd- did it.
    Have a 1994 Toyota pickup 4cyl 4wd- does it.
    Have a 2006 Tacoma Access 4cyl 4wd- does it.
    I'd say it's normal...
    kidthatsirish and Jimmyh like this.
  4. May 2, 2023 at 8:28 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I agree that some slight vibration is normal. Every manual I have ever driven with a floor shifter has had a vibration in the shifter in neutral with the engine running. The only ones that didn't are the manual with the shifter on the steering stalk.
