stick shift shakes!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by panardo, Oct 16, 2017.
  1. Oct 16, 2017 at 8:50 PM
    panardo
    panardo [OP] Well-Known Member
    Taco 2000 4x4 V6 manual w/RDlock
    On my 2000 tacoma V6 w/manual transmission, the stick shift shakes at 65 mph, and gets worst when hitting a crack on the pavement, replacing center bearing and Ujoints of the drive shaft did not make it better....transmission mount is still in shape.
    a friend of mine said that it is normal, but I still think that it is not.
    should I worry about it?let me know
    here is a short video of it
    https://www.youtube.com/watch?v=In7-l7FvR7I
    thanks!
  2. Oct 16, 2017 at 9:01 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    You need to replace the bushing/seat for the gear shifter. Some of the manual trans guys can give some more input. @Speedytech7 would have more knowledge about it.
    Speedytech7 and gearcruncher like this.
  3. Oct 16, 2017 at 10:07 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  4. Oct 17, 2017 at 5:58 AM
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    Mine shakes when off-road on really bad corrugations and when I take ruts too fast :spy:
    Onroad mine is smooth. So that appears a little abnormal.
    Still not as bad as a JK lol
  5. Oct 18, 2017 at 3:30 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    There are three causes of shaking, first the whole drivetrain is rubber mounted (unless you already changed that) so the whole thing will move and thus the stick will too of and on road. Second, the body of the truck moves on the frame so it will make it seem as if the stick is moving. Lastly the shifter bushings can be going out which I have plenty if pictures of if you'd like them and you can replace the shifter bushings with Delrin and that will solve that issue as well as any difficulty engaging gears.
    panardo[OP], scocar, TireFire and 2 others like this.
  6. Nov 26, 2017 at 7:39 PM
    WTtoolman
    WTtoolman Facial bones colapse as I crack your skull in half
    William
    Omaha, NE
    2006 Access Cab 4x4 TRD SWB
    5100s at 0, eibachs, 2" toytec AAL,, Moto Metal 951b, BFG A/T
    Are the delrin shifter bushings you speak of OEM or after-market??
  7. Nov 26, 2017 at 8:07 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  8. Nov 26, 2017 at 8:22 PM
    Speedytech7
    Entirely aftermarket, awesome product though. The OEM seat is designed from the point of view of reducing costs and vibration felt in the stick. But the stick itself is already rubber isolated so there isn't much point in having the seat be a wear item in my mind.
  9. Nov 26, 2017 at 10:12 PM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    I just installed both the shifter bushing and shifter seat this afternoon and can confirm, it makes a big difference. It was getting difficult to go into 4th gear for me and there was some play in the shifter when engaged (not as bad as in your video but definitely there) and now the truck shifts more smoothly and there's almost no movement whatsoever when in gear.
    scocar and Dalandser like this.
  10. Nov 26, 2017 at 10:19 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    What did your socket / bushing at the end of the shift lever look like before replacing it? Take any pics?
  11. Nov 26, 2017 at 10:33 PM
    03 NIGHT TACO
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    I forgot to take pictures :frusty: but the bushing and socket actually both looked to be in pretty decent shape, which surprised me, except that the bushing was made from really flimsy rubber (it was blue, not sure if it was OEM or not) and it was two pieces - the bushing itself and a separate rubber gasket. The new delrin one looks to be much more durable.
    Dalandser[QUOTED] likes this.
  12. Nov 26, 2017 at 10:46 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    The previous owner of my truck had a short shift kit installed and whoever installed it didn't do it correctly, leaving the shifter sticking too far into the transmission so the bushing ground away and it began to hit metal on metal. I thought I needed a newer transmission and after buying one and swapping the shifter into my current transmission I realized it was all the shifter - shifting into each gear was easy once I swapped levers. Oh well, at least I got a good deal on the trans and the motor from the same truck. lol
    You can see how the top bushing is worn off and the metal sticks out at the end:
    This is what the metal was rubbing on in the transmission:
    03 NIGHT TACO[QUOTED] likes this.
  13. Nov 27, 2017 at 11:36 AM
    03 NIGHT TACO
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    :eek: wow, that's insane! I didn't even know it was possible to install the shifter too far into the transmission... does that have to do with the short throw kit?
  14. Nov 27, 2017 at 11:41 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yeah they botched the install somehow - I haven't had a chance to tear it apart and figure out how they messed it up yet.
  15. Nov 27, 2017 at 8:50 PM
    WTtoolman
    William
    Omaha, NE
  16. Nov 27, 2017 at 8:57 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    No, I've only had a 5 speed in both my trucks so I never really looked into it - I wouldn't be surprised if you called Marlin and they may have an answer for you though - them or URD or LCE!
  17. Nov 28, 2017 at 9:35 AM
    Bruno#131
    Bruno#131 Member
    2016 sport ssm dclb 4x
    Anybody live close to Marlin Crawler and want to ship me the seat and socket for my truck? They claim it’s a minimum price on all shipments even if it’s a few oz’s so I’m not spending 10$ to get shipped to Alabama.
  18. Nov 28, 2017 at 5:05 PM
    03 NIGHT TACO
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    I feel ya. I paid over $10 to ship mine to eastern Washington :eek:
  19. Nov 28, 2017 at 6:15 PM
    Bruno#131
    Bruno#131 Member
    I know it’s total madness
  20. Nov 28, 2017 at 7:03 PM
    vettehigh
    vettehigh Tacoma Tank
    Jon
    Upstate, NY
    On my 95 auto...it shakes when I go over a bump and your hear the plastic knob shake also. Is there any fix for that with the automatic?
