Sticker/decal removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MattCOtoy, Oct 24, 2017.
  1. Oct 24, 2017 at 6:18 PM
    MattCOtoy
    MattCOtoy [OP] Well-Known Member
    2014 Tacoma
    Not an important topic just seeing about any hints before I take every sticker and decal off my truck, I want to clean it up. Plus got a white Tacoma with silver decals so take off the two side door Tacoma decals and replacing with black ones
  2. Oct 25, 2017 at 8:30 PM
    MattCOtoy
    2014 Tacoma
    Heat gun? Heard fishing line?
  3. Oct 25, 2017 at 11:21 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Heat gun and plenty of patience.
  4. Oct 26, 2017 at 4:56 AM
    Justbrian
    Justbrian Well-Known Member
    Brian
    Tulsa OK
    2014 TRD OR
    Yep, heat it up going back and forth over the decal, don’t let it sit in any one spot for too long. After that work some fishing line under one corner and gently pull until the whole thing is peeled off. Afterward I use bug and tar remover to get any sticky residue off then clean it up with a spray detailer and microfiber towel.
    igno1tus and PvilleJohn like this.
  5. Oct 26, 2017 at 4:59 AM
    PvilleJohn
    PvilleJohn SVT Raptor
    Powdersville SC
    SVT Raptor
    As it's been said...Heat gun (hair dryer) works fine for this....Heat it up, use fishing line or dental floss to cut the emblem off. Once you heat up the left over adhesive it literally will roll right off with your thumb. Finish it off with a little adhesive remover and its gone.
    Key-Rei likes this.
  6. Oct 26, 2017 at 5:02 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    You may be left with a ghost image where the UV light never touched the paint behind the badges, I used a dual action polisher to smooth everything out and hide the ghost badging. Finished with a nice coat of collonite wax and it's like it was never there.
    SweatyTaco and PvilleJohn like this.
  7. Oct 26, 2017 at 5:04 AM
    faststang90
    faststang90 Well-Known Member
    dwayne
    houston
    2010 Pre Runner
    I always use goo gone it works good.
  8. Oct 26, 2017 at 5:32 AM
    cekeel
    cekeel Enthusiast
    NC
    '08 Tacoma TRD Sport DCLB
    PC 6" w/ Kings, SCS w/ BFG A/T, ARB/All-Pro, N-Fab, Rotopax Magnaflow/AIRAID, ScanGauge/Pioneer, Wet Okole/WeatherTech
  9. Oct 26, 2017 at 6:13 AM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    I was a little uneasy about using a heat gun so I went with a regular hair dryer... worked out pretty well.
    Fitz235 likes this.
  10. Oct 26, 2017 at 1:41 PM
    2007tacoman
    2007tacoman Member
    2007 White Tacoma TRD Off Road
    I took my TRD stickers off with a blow drier on the low setting and some goo gone. Make sure you don't over heat as it can cause uneven wear in the paint. For the decals, try to dental floss. It will take longer than fishing line but is smoother and wont dig into your paint/clearcoat.
  11. Oct 26, 2017 at 2:19 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Yeah, I would stay away from the heat gun. There was a guy here a while ago doing the same thing, and lost a good chunk of paint. As has been said already, blow dryer will be plenty hot for what your doing.
  12. Oct 31, 2017 at 1:27 PM
    jhunter80
    jhunter80 Well-Known Member
    Southern California
    2017 TRD Off-Road Pre-runner
    A.R.E. Z Series Shell Clazzio Leather Seats Bilstein 6112 (2nd Notch/0.75" lift) Bilstein 5100 (Rear) SCS F5 Wheels (16x8/4.5 Backspacing) Goodyear Duratrac 265/75R16 (C Load Range)
    Never thought I'd say this, but after reading this thread I think my wife has better tools for this than I do ... Going to try the blow dryer / floss combo on my TRD OR decals.
