Sticky brake drum, what bolt size for removal?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Aught2TaCO, Sep 21, 2014.
  1. Sep 21, 2014 at 8:33 PM
    Aught2TaCO
    Aught2TaCO [OP] Well-Known Member
    Troy
    Wheat Ridge, CO
    '02 Taco TRD, aka Pearly
    Billie 5100's, new leafs, Falken WILDPEAK A/T 3W, 265/75/16E
    My drums are warped and need to be resurfaced, but I'm unable to remove a stubborn drum. What is the bolt size that removes the brake drum? 6mmx1.25mm? I can't remember, and my search button failed to yield my answer.
    HansWorldTravels likes this.
  2. Sep 21, 2014 at 8:52 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    There is no bolt holding drum , you're brake shoes are extended into the worn surface of drum thats why its sticking, you need to adjust the shoes in until it clears the drum...
    cosmicfires likes this.
  3. Sep 21, 2014 at 9:41 PM
    Aught2TaCO
    Troy
    Wheat Ridge, CO
    Let me explain... There are two threaded bolt holes on the face of the drum, opposite of each other, that assist in removing the drum when difficult. They basically "walk" the drum off the shoes when being tightened. I've done this before many years ago and it works. I need that bolt size.
    I backed the shoes off all the way, and beat the crap out of it with a plastic dead blow mallet, and I sprayed PB Blaster around the hub only, didn't want to soak it, all with no luck. The other side looked great with a good 1/2 of the shoes worn, but the drum warpage on the stuck side makes me think extra wear and a ridge that the shoes can't pass.
    The bolts have to be at least 2.5 inches long (60mm?), but with those bolts and a little banging around, a stuck drum comes off pretty easy. I just can't remember the bolt size :(
    cryptolime and HansWorldTravels like this.
  4. Sep 21, 2014 at 9:45 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I've got two bolts that I found just for this reason. For the life of me I couldn't tell you what size they are. I think they may be M8 x 1.25 but don't quote me on that. It's a pretty small bolt somewhere in the M8/M10 range and it's definitely a fine thread pitch so I don't think it's higher than 1.50. You can usually find these type of bolts in an auto parts store. Don't bother looking in Home Depot or Lowe's.
  5. Sep 21, 2014 at 9:50 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Bolt size is M8x1.25. Be sure to back off the star adjuster in case a shoe had worn a groove in the drum (which can also cause the drum to be stuck).
  6. Sep 21, 2014 at 9:51 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Yeah, its M8-1.25 (30mm or longer).
    Vanski4X4 and HansWorldTravels like this.
  7. Sep 21, 2014 at 9:54 PM
    Aught2TaCO
    Troy
    Wheat Ridge, CO
    If they're M8 x 1.25, that's the same size of skid plate bolts. Can you remember what the bolt head size is?
  8. Sep 21, 2014 at 10:11 PM
    Aught2TaCO
    Troy
    Wheat Ridge, CO
    Thanks guys! I now know what to get at Ace. Yeah, I'm thinking the shoes wore a nice ridge into the drum, I want the easy assist. 30mm is too short for me, little more wiggle room is good. BTW, Pearly just turned 118K yesterday, and I think this is the first time the drum has been removed. The paper between the drum/axle is still intact. Thanks again everybody for the help!
  9. Sep 22, 2014 at 5:16 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    On my other Taco, I had the bolts and a crow's foot and when I tried to remove it, it pulled the bolts right out of it. too much rust. Ended up I had to beat the crap out of the drum with a Sledge Hammer to break the rust holding it on the center hub. Finally after scoring it to deth it came off.
  10. Sep 22, 2014 at 6:00 AM
    Aught2TaCO
    Troy
    Wheat Ridge, CO
    That is not what I want to do, the drums are still good, just warped. I priced drums through Carquest, and OEM Brembo's are $120 each. Ouch.
  11. Sep 22, 2014 at 2:56 PM
    KenLyns
    Belly of the Beast
  12. Sep 22, 2014 at 8:28 PM
    Aught2TaCO
    Troy
    Wheat Ridge, CO
    Wow, thanks for the heads up :thumbsup: I'm gonna take a look around there for other stuff. Gotta go!
  13. Jun 20, 2018 at 10:13 AM
    HansWorldTravels
    HansWorldTravels Well-Known Member
    Hans
    Colorado/NY/Germany
    '03 Toyota Tacoma 3.4L Ext Cab TRD
    Roll & Ram repairs on '95 Front end crash repairs on '03
    pretty certain that is not the intended method on using those threaded bolt holes.... as a pry-point.
    mine were showing rust breakdown on the outside of the drum... so I “delicately” got the rust out & made sure not to lose/strip the threads getting the bolts in. Once I was sure of having about 3 threads worth, I tighted both down equally, beat the face of the drum with a rubber mallet rotating it, tightened both ~half a turn, beat it again, repeat... until there was loud pop and the drum came free from the axle face.
    worked like a charm both sides, using both threaded bolt holes simultaneously... ie buy at least 2 bolts
  14. Jun 20, 2018 at 12:15 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Being there only a few threads in the drum if they are really stuck they will pull right out.
    Best of luck.
  15. Jun 20, 2018 at 12:39 PM
    Glamisman
    Glamisman Well-Known Member
    8 X 1.25 X at least 100mm all tread, no sholder. I say at least 100mm because if it shoes are bound/rusted and you cant get the auto adjusters to un-adjust, you are going to have to "walk" the drum past the width of the shoe.
    Lord Prez likes this.
  16. Mar 14, 2020 at 12:17 PM
    Oregon_07Taco
    Oregon_07Taco New Member
    appreciate this thread! thanks!
    Aught2TaCO[OP] likes this.
  17. Mar 14, 2020 at 1:08 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    I was replacing the drums anyway, didn't matter to me if they went south or not.
  18. Mar 14, 2020 at 5:50 PM
    04TrDtAcO4x4
    04TrDtAcO4x4 Well-Known Member
    2003 Tacoma
    M8 x 1.25
  19. Mar 16, 2020 at 7:16 AM
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    I believe these are call "Jacking" bolts. I agree that you probably need to use them - along with backing off the shoes with the star wheel if they are out- to remove the drum.
  20. Mar 24, 2020 at 5:09 PM
    Saiko
    Saiko Well-Known Member
    Saiko
    Chicago
    00 2RZ w59 2wd
    asking for a friend, hand brake was down right? :D
