sticky brakes
Discussion in '1st Gen. Tacomas (1995-2004)' started by vtframer, Jul 25, 2017.
  1. Jul 25, 2017 at 11:30 AM
    vtframer
    vtframer [OP] Well-Known Member
    Vermont
    2001 Tacoma SR5 Extended Cab, 4x4 Manual Trans.
    anyone have experience with sticky brakes on the first gen? i noticed that it's worse when the brakes are cold. it takes almost no pressure and they seem to seize the rotor. once i've driven it a few mins, it seems to go away. the brake pads look good and the rotors look smooth.
  2. Jul 25, 2017 at 2:16 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Getting any oil or grease on the Rotor at all.
    From it sitting just enough to grab but not enough to make a big mess
  3. Jul 25, 2017 at 2:20 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Sounds like the piston(s) are sticking a bit. Verify by pulling the caliper and checking even wear on the pads. My truck did the same when I bought it new.
    I suggest up-grading to the Tundra rotors & calipers too, big difference in stopping power.
    God luck.
  4. Jul 25, 2017 at 2:41 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I sometimes notice this if it's rained the night before. The brakes will "grab" a little more when I first start out. They return back to normal after a little driving.
  5. Jul 26, 2017 at 1:25 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    You could try pulling the pads out and placing sand paper on a flat surface. Wear a mask. Then rub the pads over the sandpaper just enough to scuff them.
  6. Jul 26, 2017 at 1:29 PM
    vtframer
    Vermont
    thanks all for the advice!
  7. Jul 28, 2017 at 4:59 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    could be your guide pins are rusty and sticking...
