Sticky clutch 17' 6spd
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dnlskier, Dec 20, 2016.
  1. Dec 20, 2016 at 8:47 AM
    dnlskier
    dnlskier [OP] Well-Known Member
    17' TRD SPORT MT
    Hi All!! Just got my first Taco 2 weeks ago after many years of dreaming - 2017 TRD Sport 4dr 6 speed. I have had it for ~2 weeks and LOVE IT!! Anyway, we have had a few cold days between 5F to -5 before windchill here. My question is the clutch seems very stiff even after the truck warms up and even after 18 miles of driving to work. Is this normal or should I have it adjusted a bit? This is my 4th manual vehicle and never had this before. Above ~15f or 20f the clutch feels normal.
    Thank you for your help and/or ideas
    Cheers,
  2. Dec 20, 2016 at 8:55 AM
    Farcedude
    Farcedude Well-Known Member
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
    Shikokaon likes this.
  3. Dec 20, 2016 at 9:00 AM
    dnlskier
    17' TRD SPORT MT
    Thank you for the reply and link. When I bring it in to the dealer ~5000mi I will bring it up.
    Cheers,
  4. Dec 20, 2016 at 9:03 AM
    Shikokaon
    Shikokaon Slacker Extraordinaire
    Portland, OR
    2017 Tacoma D-Cab Off Road (MT)
    Sounds like the fluid just gets too thick when that cold. Never been in an environment that cold, but Google-ing some folks change their fluid to something thinner during winter, and then to something thicker during the warmer months...
    Besides the $ to be doing changes, not sure on if it'd create other issues...
    Hopefully someone with Real Life Cold Weather experience can chip in and give you sound advice ...
  5. Dec 20, 2016 at 9:05 AM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    Mine is three years old and it gets as stiff in the cold as it did the first winter I had it. I don't think it's a problem, as long as your clutch never slips when you hit a new gear. Mine never has.
    Just keep driving it man, and be thankful you had a manual tranny on the icy, wintery roads.
    Spare Parts likes this.
  6. Dec 20, 2016 at 9:07 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    All the 2nd and 3rd gen's do this. Hydraulic clutch and the fluid thickens making it hang up til it warms a bit
  7. Dec 20, 2016 at 9:43 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My 2008 did not due this as the brake and clutch shared the same reservoir, my 15 has the clutch reservoir out on the fender and it gets a little slow in the cold.
  8. Dec 20, 2016 at 9:53 AM
    6172crew
    6172crew Well-Known Member
    New Mexico
    4X4 TRD sport
    I was thinking about swapping to motul, its in the 20s in the morning and the clutch is spongy.
  9. Dec 20, 2016 at 10:44 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Yes, it's stiff, but my 09 I almost had to pull it up with my toes, so this one is pretty good. I find that a few extra pumps when at a stop helps.
  10. Dec 20, 2016 at 10:57 AM
    dnlskier
    17' TRD SPORT MT
    Hmm.. Again thank you all! The tranny never slips when shifting, but sounds like it is common so I will keep on enjoying my new truck woo hoooo!!!
    timothom likes this.
  11. Dec 20, 2016 at 11:04 AM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    Just wait until it temperatures warm up a bit and you get some miles on the truck. Then you'll have they creaky wooden floorboard clutch :)
  12. Dec 20, 2016 at 11:06 AM
    shakerhood
    Southern Ohio
    That is easily corrected with a little Disc Brake Grease, I found that to be the only lubricant that would stay put under there.
    mict450 likes this.
  13. Dec 20, 2016 at 11:06 AM
    Spare Parts
    Southern Maine
    and I will happily drive with the creaky wooden floorboard clutch, as its better than what the automatics sound like.
    bobrown14 and shakerhood like this.
  14. Dec 21, 2016 at 4:06 PM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    The hydraulic fluid for the clutch is brake fluid....ummmm pretty sure that stuff is engineered to handle cold temps as well as extreme hot temps.
    My clutch gets sticky anytime under say 30F until warmed up. I bet its the rubber seals in the clutch master cylinder. Doubt its the fluid or we'd have other more critical issues.
  15. Dec 22, 2016 at 6:54 AM
    6172crew
    New Mexico
    4X4 TRD sport
    I cant find anything on the operating temps of the dot 3 fluid they use. Brake fluid seems to be engineered for hot temp, but cant find much about cold. Looks like this problem has been around for 3 generations from what google has to say. Even the 2nd gen had a tsb and replacement parts including the fluid. Mine get stored in a garage so it isnt too bad.
