sticky clutch
Discussion in '1st Gen. Tacomas (1995-2004)' started by fivesix, Jan 12, 2009.
  1. Jan 12, 2009 at 7:19 PM
    fivesix
    fivesix [OP] Member
    Kentucky
    99 Tacoma 6cyl.
    My clutch sticks about 1-3 inches from the top when I let off of it. You guys know what type of problem I'm having? I also have trouble starting the truck sometimes. Just a clicking noise but no start. I just replaced the battery and thought that cured the problem until today I had the same problem. Not a mechanic so I need help before I spend a ton of money.
  2. Jan 12, 2009 at 8:33 PM
    mudjunkie
    mudjunkie Well-Known Member
    clearwater fl
    96 tacoma sx l
    header,short rack and pinion, heavy duty shocks, grill guard, flowmaster exhaust,pacesetter header without catalytic converter, one 10 inch xant sub with a mtx amp, off road lights,diamondplate tool box,rhinolined inside cab,ngk plugwires.
    explain the cluthch problem a little bit better as for the starter issue sounds like your solenoid check your starter connection to see if it is clean and tight. also check your battery connection make sure they are clean and tight.
  3. Jan 12, 2009 at 8:38 PM
    fivesix
    fivesix [OP] Member
    Kentucky
    99 Tacoma 6cyl.
    Thanks for the tips. THe clutch works fine but I have noticed it starts sticking when I release it. It stops a couple of inches from the top when I shift gears. Usually when it is cold. I can tap the clutch with the side of my foot and it pops all the way out. About all I can tell you. Thanks for any suggestions.
  4. Jan 12, 2009 at 10:36 PM
    TengoTaco
    TengoTaco Newb
    La Quinta, CA
    2020 OR 4x4 Manual
    8112, SPC, Elka 2.0 rear and Icon AAL. About 1.5”
    I had a similar issue. Mine was coming short only a half an inch to an inch though.
    I pulled my clutch pedal out. I was missing one of the bushings. While i had it out i replaced the other two. I greased it up and it worked like a charm...
    Here is a link on how to replace the bushings...
    http://www.lieblweb.com/tacoma/Mecha...tchBushing.htm
    Good luck!
  5. Jan 14, 2009 at 9:20 AM
    fivesix
    fivesix [OP] Member
    Kentucky
    99 Tacoma 6cyl.
    Thanks Tengo. A buddy adjusted the clutch for me and seemed to fix the problem. I will also check the bushings.
  6. Jan 14, 2009 at 9:44 AM
    98tacoma27
    Ben
    Not Beech Creek
    The clicking when starting is probably the starter contacts. These are a replacable item.
  7. Jan 15, 2009 at 9:05 AM
    yaker
    yaker hey yall watch this
    G-Town, Arkansas
    Bad Ass 99 tacoma TRD OFF ROAD SR5
    3" PA body lift spacers in front, 2" Wheelers add a leaf in back, 5125 billys, 33x12.50MTRs, custom sliders and bumpers, High lift jack mounts, spare tire mount in bead.
    check the luch fluid levle.
  8. Aug 23, 2010 at 10:03 AM
    apehead
    apehead Member
    Jackson
    Middletown, CT
    95 Tacoma 4x4, 5 spd, 5vz-fe, std cab
    Front leveling kit
    Glad to join the forums, and to find a dead thread to revive! My clutch is having a similar problem.
    In high gears (1st and R) my clutch will not spring back up after I have released it. In 2nd, it will hesitate, and then spring back into its normal position. It also seems that the longer I keep the clutch depressed, the more likely the sticking will occur.
    Any thoughts?
  9. Aug 23, 2010 at 10:07 AM
    98tacoma27
    Ben
    Not Beech Creek
    Replace the spring?
  10. Aug 23, 2010 at 10:08 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    slave cylinder. Also check the fluid level
  11. Aug 23, 2010 at 11:40 AM
    apehead
    apehead Member
    Jackson
    Middletown, CT
    Front leveling kit
    Thanks for the suggestions. Are these repairs fairly straight-forward? I have the service manuals, but I don't have anything besides basic hand tools and no garage to work in. Do-able?
  12. Aug 23, 2010 at 11:41 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, they are "drive-way" doable
  13. Aug 23, 2010 at 5:24 PM
    apehead
    apehead Member
    Jackson
    Middletown, CT
    Front leveling kit
    Cool. I checked the fluid level, it is full. Would it be worthwhile to attempt to bleed the system before replacing anything?
  14. Aug 24, 2010 at 5:40 AM
    apehead
    apehead Member
    Jackson
    Middletown, CT
    Front leveling kit
    Just FYI, some good info for noobs like myself here.
  15. Aug 25, 2010 at 4:18 PM
    apehead
    apehead Member
    Jackson
    Middletown, CT
    Front leveling kit
    replaced the slave cylinder, bled system. Still not returning to engaged position after being depressed. Could it be the master cylinder? Had a friend press clutch while I looked at slave cylinder and clutch fork. Pushes fork fully a few times, then less and less, until the pedal is on the floor.
    Please help!!! This is my daily driver!!!
  16. Aug 25, 2010 at 6:52 PM
    Quast
    Quast Well-Known Member
    Dustin
    Mission, BC
    03 toyota tacoma 3.4L
    3'' OME lift, Deck plate mod, spidertrax wheel spacers, 12'' alpine type S sub.
    i had a similar problem changed the master and slave cylinder. works well now. change out your master cylinder its your problem. make sure that when you do it that you tighten the lock nut securley to the clevis part and put a wrench on the clevis even when pined it will still turn freely. i belive a 3/4 wrench and a #12 for the lock nut. bleed the system and check freeplay should take no more then 2 hours. hopefully this helps.
