Sticky cold shift while running 96 SR5
Discussion in '1st Gen. Tacomas (1995-2004)' started by dmstream, Feb 29, 2024.
  1. Feb 29, 2024 at 10:10 PM
    dmstream
    dmstream [OP] GVWR Is Just a Suggestion
    Dana
    Washington Peninsula
    96 SR5 MT w/ 06 Lite-Craft Timberline
    OME Supercharger+ front assembly OME Dakar rear leaf pack with overload spring installed (7 inches over stock lol) SPC UCAs Carrier bearing drop kit 13WL Front brake upgrade Slee off-road steel braided front and rear brake lines Magnaflo muffler with custom piping Wood bead seat cover Raptor spray in bed liner 265/75/16 Firestone Dedtination XT 3rd gen 4Runner wheels
    Hey all
    I’ve looked at a bunch of threads and have checked off a couple steps with a couple more to go. Next is diving in to the truck a lot further.
    Wanted to ask about my specific situation.
    while the engine is off the transmission shifts smoothly between gears.
    when the engine is running cold, the transmission will not shift into first. With a large amount of force it may shift into second, but sometimes not at all (no other gears either)
    when running hot, or off, the transmission is butter for all gears.
    have you run into this with a 96 sr5? What was the cause/fix?
    So far I have changed the transmission, transfer case, and rear diff with redline gear oil. I don’t think the clutch pedal comes into play due to the smooth hot shifts. Overall, after the oil change, it has become smoother during hot operations, but the cold problems have persisted.
    thanks for any responses, even if you didn’t have the same issue, any ideas are welcome.
    #1stgensuperiority as always.
  2. Mar 1, 2024 at 12:53 AM
    Kosta
    Kosta New Member
    Masen
    1995.5 Tacoma//1994 Miata
    I don't have a solution but I have the same problem, mine goes into 2nd fine but 1st is always kind of a pain. I hope someone on here has a solution or diagnostic.
    dmstream[OP] likes this.
  3. Mar 1, 2024 at 6:26 AM
    TobsterStrudel
    TobsterStrudel Well-Known Member
    Florida
    '98 XtraCab 3.4 V6 M/T
    I had a very similar issue, but it COULD shift into first if I used way too much force on the shifter, but it was ridiculous.
    It got worse and worse until the pushrod (31404-28020) snapped in half during a road trip, I had to get it welded at some mechanic.
    I reckon the clutch master cylinder wasn't being fully depressed, so it didn't function as intended. As soon as my engine warmed up however, it became easier because I was pretty much using half clutch presses unknowingly.
    EDIT: You might just need to change the position of those screw threads and nut to spec, that helps a ton if your part isn't falling apart like mine was.
  4. Mar 2, 2024 at 1:01 PM
    dmstream
    Dana
    Okay thanks for that picture that answers a question i had about what people were actually talking about with that. I'll check mine out today.
  5. Apr 22, 2025 at 6:07 PM
    dmstream
    Dana
    For a follow up: All I had to do was hook my toe under the clutch pedal and pull it back toward me. Occasionally I'll have to do it again, but shifts smooth as butter. I'm sure it'll force my hand to take care of it eventually
  6. Apr 23, 2025 at 4:42 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    Sounds like a failing master or slave cylinder.
