Sticky Steering
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yotaco02, Jun 23, 2010.
  1. Jun 23, 2010 at 5:23 PM
    Yotaco02
    Yotaco02 [OP] New Member
    Randy
    Ct USA
    '02 Tac0 4x4
    Hello Tacoheads...newbie here. I've had my '02 for two years now it's got 115k and runs great. 4cyl 5 speed. Recently (4 months ago)had the factory frame change done. Past two weeks the front end (or something) seems to hold the steering wheel while your in a turn. I can control it but it seems like it kinda of stays in the position you put it and if you take your hands off it it dosen't strighten out. something needs to be lubed or??????:notsure: Thanks
  2. Jun 23, 2010 at 9:36 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Are you lifted? Larger than stock tires? Is there even wear on the front tires?
  3. Jun 23, 2010 at 11:21 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The characteristick you describe, sounds like it related to your allignment - CASTER.
    Did Toyota give you any 'warrantee' period after the frame was installed? I'm thinking....that maybe you need to go back and have everything re-checked.
    Did they do an allignment after the frame was installed?
  4. Jun 24, 2010 at 3:41 AM
    Yotaco02
    Randy
    Ct USA
    '02 Tac0 4x4
    No. Not lifted. Big tires but thety are stock size
  5. Jun 24, 2010 at 3:42 AM
    Yotaco02
    Randy
    Ct USA
    '02 Tac0 4x4
    I have to check about the frame warranty. But , yes, they did alighn the truck after frame was done
  6. Jun 24, 2010 at 6:23 AM
    shift96
    shift96 Well-Known Member
    Well my guess if if the Dealer aligned it they screwed it up. Take it to a real tire shop that knows what they are doing.
  7. Jun 24, 2010 at 6:52 AM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    If it was ok after the alignment was done, but just starting acting up, I would say it sounds like front end parts starting to go bad. Balljoints would be my first guess.
  8. Jun 24, 2010 at 7:43 AM
    Janster
    Jandy
    Lancaster, PA
    I would contact the dealer who put the frame in....there should be some sort of 'warrantee' for their labor. Because, after 4 months....stuff can start to come loose. And honestly....If they don't re-check things for free, I'd start complaining!!!
  9. Jun 24, 2010 at 6:19 PM
    Yotaco02
    Randy
    Ct USA
    '02 Tac0 4x4
    I was thinking ball joint too. Do you think it would be the steering ball joints or the upper and lower control arm joints? I put a long bar under the tires while the truck was lifted up and I can't "feel" any play. Any way to narrow this down to one or the other and if it is the steering joints should both be done and is that a big deal. I'm not afraid of getting my paws dirty and am pretty mechanically inclined. Any special tools? Hey, thanks alot for your guys help:)
