Sticky tack for the dash?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by atvaholic, Jan 16, 2011.
  1. Jan 16, 2011 at 7:41 PM
    atvaholic
    atvaholic [OP] New Member
    Hi, trying to mount my scanguage on the dash and have tried a few different types of velcro. The problem is it stays on there about 2 days then falls off.
    Can anyone suggest something that will hold?
  2. Jan 16, 2011 at 9:05 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    Well.. might be that you put armorall on there at some point. I don't know why you'd have problems. Use some prep-sol or wax/grease remover then some alcohol and probably be fine with some good quality self adhesive heavy duty velcro or 3m trim tape. I've damaged dashes trying to force that stuff off in similar circumstances.
    Careful with the prep sol.. "try on an inconspicuous area first" on my GM turned out it would dissolve the paint the dash was painted with. Wax and grease remover was fine though.
    Might get one of those universal cell phone mounts as well.. clamp it up there with a suction cup or something.
  3. Jan 16, 2011 at 10:04 PM
    atvaholic
    Hi Island... I did have armor all on there. But I also did using rubbing alcohol to clean the area before I stuck it on. It's been mighty cold here recently and im wondering if thats the problem. I do have an insulated garage, but it still can get cold in there.
  4. Jan 17, 2011 at 12:23 AM
    island808
    Jedediah
    hawaii
    alcohol will not remove the armor all if I know what's in it correctly.
    The tape will have a temperature threshold. Using craft velcro or auto?
  5. Jan 17, 2011 at 12:26 AM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Use one of those small rubber pads, they grip it well in my truck. Then put the velcrow sticky side on it and it will be a good mount without leave a mark on your dash.
  6. Jan 17, 2011 at 12:34 AM
    Stanley
    Stanley Well-Known Member
    Breckenridge, CO
    06 SR5 Silver
    Debadge, 5% Tint, Kolbalt Low Pro Tool Box, Satoshi, Ebay Black Headlights, 3000k Fogs With Yellow Stain glass Paint, Fog Anytime, Mag Light Mount, Husky Floor Liners, OME 3inch With 885's, Add Leaf, 16inch Steelies, 305/70/16 Dick Cepek Mud Countries, Tiregate Bed Mount, Sock Monkey Badges
    had an epic fail with adhesives and the sun on dashes in the past. i try to avoid it all together
