sticky throttle
Discussion in '4 Cylinder' started by hortona, Aug 30, 2014.
  1. Aug 30, 2014 at 8:24 AM
    hortona
    hortona [OP] Well-Known Member
    99 tacoma SR5 w/ 3rz-fe
    gas pedal is sticky pushing in when engine is on. But it is smooth as butter when engines off? any suggestions
  2. Aug 30, 2014 at 9:10 AM
    weezer
    weezer Well-Known Member
    southeast
    tacoma 4x4
    Bilstein 5100 shocks, OME lifting springs, Ivan Stewart 16x8 wheels, AT tires
    maybe clean throttle body. it's drive by wire so throttle body butterfly doesn't move if truck is turned off.
  3. Aug 30, 2014 at 9:12 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    TPS going out? Throttle Position Sensor.
  4. Aug 30, 2014 at 9:29 AM
    weezer
    southeast
    tacoma 4x4
    what is tps? just curious
  5. Aug 30, 2014 at 10:40 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Weezer, this older truck is NOT 'drive by wire'. Don't assume that all Tacomas are exactly like yours.
  6. Aug 30, 2014 at 7:43 PM
    tacoma4
    tacoma4 Well-Known Member
    Does yours have cruise control? Maybe that cable is messing with it when it's running?
  7. Aug 31, 2014 at 9:23 AM
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    clean and lubricate throttle body, lubricate cables. Should fix you right up
  8. Aug 31, 2014 at 10:44 AM
    tan4x4
    Rick
    Folsom, CA
    Thats a good idea. Maybe the servo is stuck on when running, so its resisting the pedal action
  9. Aug 31, 2014 at 11:19 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    :rofl: :rofl:
  10. Aug 31, 2014 at 4:38 PM
    weezer
    southeast
    tacoma 4x4
    my bad. i thought my old 1988 was drive by wire. sorry i got it mixed up. :D
    anyways sounds like the same solution either way. clean the throttle body.
  11. Sep 15, 2014 at 1:13 PM
    HB2010
    HB2010 Member
    2005 TRD sport package double cab
    Where can I get more info on" Throttle Position Sensor" and how to replace it?
    mine is a 05 V6 Automatic.
    Thanks.
  12. Sep 15, 2014 at 3:25 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    It shouldnt need a sensor for throttle position, its drive by wire.
