Stiff Bilstein 5100
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tristizzle, Jun 24, 2020.
  1. Jun 24, 2020 at 12:11 AM
    Tristizzle
    Tristizzle [OP] Member
    Tristin
    2016 Black Off Road 4x4
    Hey everyone,
    recently installed an icon 1.5” AAL in the rear and Bilstein 5100 with OME 888 springs. The ride seems to be very stiff. I can’t even go over a bump in a parking lot with my front end basically slamming down. Maybe I just need to break them in?
  2. Jun 24, 2020 at 1:04 AM
    sandyTrd87
    sandyTrd87 Well-Known Member
    Socal
    Bilstien 5100's x4 Dobinson 448 springs, rear 2inch AAL
    Sounds about right I would give it a few days to settle. Unless you hear clanking it banging then check it.
  3. Jun 24, 2020 at 1:05 AM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    What perch are the 5100s set to?
    FishnTx likes this.
  4. Jun 24, 2020 at 1:05 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I have 5100s on mine and it rides great, but I'm on stock coils which I think makes a difference. My sons truck is on the highest setting and it rides the same as mine which is on the 4th setting. Maybe its your coils, but your one of the few that I have read complain about them. Give them a chance to break in, also Bilstein recommends to use factory coils so you don't void the lifetime warranty and they were designed for use with factory coils. Again it doesn't matter which setting/perch the ride is the same, ask me how I know. I have two trucks set up on 5100s on different settings and no it doesn't compress your coils.
    shady 74 and 71tattooguy like this.
  5. Jun 24, 2020 at 1:24 AM
    jmauvais
    NorCal
    ...stuff
    wrong. Stock coils, doesn’t matter what perch. You will arguably get a different ride with different perches, but that is neither here nor there.
    OME coils are designed for the bottom perch only, they are longer than stock coils.
  6. Jun 24, 2020 at 1:39 AM
    VaToy
    Parts Unknown
    I guess Im the only one that has two 3rd gems with 5100 on different perchs, set up the same way, same wheels and tires and ride identical. That's just not correct, might wanna check into that a little more. My friend he was on OME coils and had 2 sets sag, the ride was not any better than with the factory coils which he is using now. I will agree to disagree and leave it at that.
    thecooklook and 71tattooguy like this.
  7. Jun 24, 2020 at 5:48 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    4th perch here. No complaints. 5100’s are designed to be used with oem coils. They supply the lift people want without sag. IMO 5100’s with oem coils that’s it. You want more lift or new springs go with 6112’s or Eibach kits.
    VaToy[QUOTED] likes this.
  8. Jun 24, 2020 at 6:01 AM
    rooney2oons
    rooney2oons Well-Known Member
    Dallas, Tx
    2016 TRD Off Road Silver
    Nothing yet....im a poor bastard.
    I think it even says that in the instructions. And I havent made up my mind on what lift I want.
  9. Feb 26, 2021 at 9:55 AM
    DosTacosPorvor
    DosTacosPorvor Well-Known Member
    Brad
    Midwest
    19’ TRD Sport Dbl Cab M/T
    5100’s w/AAL, Dobinson's 314 coils. 285/70-17 BFG KO2's, 17X8 Pro-Comp 89's 0 offset, BA Highline Front Bumper, K&N FIPK CAI. N-Fab Podium steps, Gatorz Low Profile Hard tri fold Bed Cover.
    Me too, I’ve talked to my local shop in Chicago that specializes in Toyota’s. He told me the 5100’s are designed to be used with stock coils and that there’s no need to spend the xtra cash. I have 5100’s sitting in my garage, only reason I haven’t installed them is I’m trying to do my research on all the folks saying it will be too stiff! Driving me nuts because I only want to do this ONCE!
    tacotoe and 71tattooguy like this.
  10. Feb 27, 2021 at 1:29 AM
    VaToy
    Parts Unknown
    I have almost 3 years and 25k miles and my tacoma drives better today than the day I bought it. Keep your factory springs, thank everyone later. My truck sits at 25K miles on the the clock and 20k on the lift. It will soften up some over time and I mean a more broken in feel. The OME coils will stiffen it up but still in a good way when driving on the highway. My friend went through two sets because of sagging, now he is back on stock coils, and his next door neighbor has a Pro which I think both ride about the same.
    DosTacosPorvor and 71tattooguy like this.
  11. Feb 27, 2021 at 1:42 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    5100s on stock coils here. "Tight" not "stiff"
    tacotoe likes this.
  12. Feb 27, 2021 at 5:24 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    5100’s are excellent IMO. DAILY / weekend warrior. Wouldn’t change a thing. :thumbsup:
    VaToy, DosTacosPorvor and tacotoe like this.
