Stiff Power Steering
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Greenpants, Apr 25, 2020.
  1. Apr 25, 2020 at 7:25 AM
    Greenpants
    Greenpants [OP] Well-Known Member
    Massachusetts
    2009 4x4 Tacoma 4 banger
    The tailgate mod
    Have any of you guys had a problem with your power steering going stiff ? Every once in a while it will go back to normal .My belt is not slipping. The Fluid is full too. Any ideas ?
    Thanks greenpants....mike
  2. Apr 25, 2020 at 7:29 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    If it gets stiff at certain points of a turn, it may be the intermediate shaft.
  3. Apr 25, 2020 at 7:35 AM
    Paulrv6
    Paulrv6 Well-Known Member
    paul
    2005 Tacoma
    I was just going to ask this same question. I have a 2005 with only 63K and my steering feels like it gets stuck at certain positions, almost like it I have to force it free. Just doesn't feel normal. Is this most likely the intermediate shaft joint locking up?
    Is there a way to know for sure before getting fixed? Thanks
    paul
  4. Apr 25, 2020 at 7:52 AM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    i have something getting stiff but its not the steering . . .
    Island Cruiser and Biscuits like this.
  5. Apr 25, 2020 at 9:08 AM
    Muddinfun
    Muddinfun Well-Known Member
    Biscuits likes this.
  6. Apr 25, 2020 at 9:26 AM
    Greenpants
    Massachusetts
    The tailgate mod
    OK, That was fun ,but what about that power steering problem. Anymore real ideas or solutions. I don't think many guys come to Tacomaworld for a comedy source.....
  7. Apr 25, 2020 at 9:27 AM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    :anonymous:
    whatstcp[QUOTED] likes this.
  8. Apr 25, 2020 at 9:55 AM
    Muddinfun
    Put lubricant on the shaft and work it back and forth. That should make the stiffness go away.
  9. Apr 25, 2020 at 10:35 AM
    Greenpants
    Massachusetts
    The tailgate mod
    Thanks to the adults that responded to my question. I did lube that shaft & it worked well. Thanks again.
    greenpants....mike
    Muddinfun likes this.
  10. Apr 25, 2020 at 11:11 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    not going to lie, I thought the lube and work it comment was not serious advice but now I am not sure.
    tcjacado and Island Cruiser like this.
  11. Apr 25, 2020 at 11:56 AM
    Fitz235
    Rob
    New Hampshire
    In any other context, I would've had to disagree with this statement.
    tcjacado likes this.
  12. Apr 25, 2020 at 12:04 PM
    Fitz235
    Rob
    New Hampshire
    Check this link:
    https://www.tacomaworld.com/threads/stiff-steering.122153/
    It basically walks you through doing what @Muddinfun advised. Should loosen it up for you.
  13. Apr 25, 2020 at 1:41 PM
    No Shoes Nation
    I am an adult and I responded, just maybe not to ur question.
    Adults, nobody said we had to be adults to use this forum . . . and to that I say I too lubed my shaft and well, you know the rest.
    tcjacado and Muddinfun like this.
  14. Apr 25, 2020 at 1:50 PM
    Rambo MARINE Recon
    Rambo MARINE Recon Well-Known Member
    Robert Goudin
    2013 Toyota Tacoma PreRunner DCLB V6 Auto. Hvy Duty
    Many, suspension, Hood Scoop,Decals and Pin Stripping, New Tires Michelens LTX MS2
    PS Fluid may be old and dirty! Flush and use a Synthectic ATF Fluid a few times and keep Synthetic Fluid in from now on! Cheap reapair! Use a Name brand as MOBIL1,AMSOIL,Royal Purple,REDLINE or more! BRAND names matter!
