Stiff Ride After New Leaf Springs - Looking to Soften the Ride
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JoeSchmuck, Feb 14, 2018.
  1. Feb 16, 2018 at 2:26 PM
    #41
    Buckwheat893
    Buckwheat893 Well-Known Member
    Cody
    Tucson, AZ
    2011 AC
    285/75 BFG K02’s. Load range E, max pressure is 80psi. 40 is more than safe
  2. Feb 16, 2018 at 2:47 PM
    #42
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    OP hasn't showed back up yet?
    This thread is full of hilarious answers, intentional or not :rofl:
    stickyTaco likes this.
  3. Feb 17, 2018 at 7:55 AM
    #43
    JoeSchmuck
    JoeSchmuck [OP] Well-Known Member
    Joe
    Virginia
    09 PreRunner SR5 2x4 O.R., Timberline Green
    Pop & Lock, Access LE Rollup Cover, Alpine PDX-5 Amp, Image Dynamics CS-6/CX-6 & 10" Sub
    Wow! This thread really has a lot of responses. Work has been crazy and this is the first chance I've had to check the forums.
    To answer the most requested question, the tire pressure is ~33 psi, if the tires drop to ~31 psi the TPS warning goes off so i inflated them just above that value.
    I like the idea of adding some weight to the bed of the truck so I'll try that first. It's not the perfect solution but it's a start.
    And I appreciate all the other suggestions and comments. I can't really complain about the ride of this truck because it does ride like a truck, but I was really use to the nice ride I had before the dealer replaced those leaf springs and there is no way that I'll convince the dealer to replace the springs with a lighter set. So I'll place a few hundred pounds in the rear and see what happens. I wonder if mulch is on sale today? I could buy 6 bags and they weigh ~30LBS each so that is 180 LBS, that would be a good test for a week or two. My gas mileage will suffer slightly but my wife might be happier if the truck isn't bouncing down the road.
    Crom and bobsuruncle like this.
  4. Feb 18, 2018 at 7:46 AM
    #44
    JoeSchmuck
    Joe
    Virginia
    Just to follow up, I did stuff seven wet bags of mulch in the back of the truck. They are much heavier than 30 LBS each but the ride has calmed down quite a bit. It's not the same as it use to be but I'm on the right path. The truck now has a slow bounce to it on some of the roads (due to road condition) so I plan to remove two bags of mulch to see how that compares and then two more after that. Could take a few days to find the sweet spot where the ride doesn't feel every crack in the road and doesn't do the slow bounce.
    Again, thanks for the advice folks. I'm not sure if this is the final solution (replacing much with sand bags eventually) or if I'll replace some piece of hardware (springs/shocks).
  5. Feb 18, 2018 at 8:40 AM
    #45
    booted
    booted Well-Known Member
    Cambridge, MD
    I believe you can set your tire pressure to whatever you want, then hit the tpms button to reset it. That way you aren't stuck over inflating just to make the tpms light go away. I usually go with whatever is on the driver's side door panel says it should be.
  6. Feb 20, 2018 at 3:57 AM
    #46
    JoeSchmuck
    Joe
    Virginia
    I don't think ~33 psi is really over inflated but I think running at 31 psi would be a better ride. Now I need to look at the door again to see what the recommended tire pressure is, I think it was 31 psi.
  7. Feb 20, 2018 at 4:38 AM
    #47
    booted
    Cambridge, MD
    I think you'll be surprised at the difference a couple psi will make. I know I was when I brought my truck home with 36psi all the way around and then adjusted it to the recommendations on the door. Rides a lot different.
