Stiff ride
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aelderski, Nov 6, 2017.
  1. Nov 6, 2017 at 3:05 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Pretty much impossible unless you get aftermarket UCA and most have that caster built in so he's probably good on alignment or at least it's not the problem here. I'd put my money on the one piece procomp AAL. That's why your ride is stiff. Ditch that POS and never put anything procomp on your truck ever again. Go with a 3piece AAL or aftermarket leaf pack
    Coot83 likes this.
  2. Nov 6, 2017 at 3:19 PM
    eon_blue
    Azusa, CA
    yeah I've heard they are hit or miss depending on the location you go to. There are a couple in the LA area around here that supposedly have techs working there that are 4x4 enthusiasts themselves and will work with you on your truck's alignment....unfortunately the ones near me and somewhat near me have proven to not be so helpful :(
    ramonortiz55[QUOTED] likes this.
  3. Nov 6, 2017 at 3:21 PM
    SkimSTI
    SkimSTI Well-Known Member
    Orange County CA
    '14 MGM TRD dblcab & '16 Mercedes C450
    Magnaflow exhaust, AFE stage 2 intake, King 2.5" resi coilover/rear shocks, Pro Comp UCA's, Deaver 1.5" leaf pack, BPF raptor style grill
    interesting thread. i have always wondered about this myself. i have the same setup as you. but i started with just the kings and left the factory leafs on...... it felt HORRIBLE on the freeway. like someone was constantly kicking me in the back every second. after about a week or 2 of being so unhappy. i bought the deaver leaf pack for the rear, which i read good things about. while it did help out quite immensly, it is still kind of harsh for the most part, i can just deal with it more now. the rear is definitely a bit more squishy on things like speed bumps (with the factory leafs speed bumps felt like the suspension didnt even budge)
    i come from having a super rigid street car (modded subaru). so i guess i was expecting to be a little smoother than that car. even the dealer that sold me the kings, said they are valved from the factory specifically for tacomas weight etc. (like almost used as selling point) - "OK this sounds great, it should be a nice ride"..... yea.... some times i wish i would have kept it more basic with the 5100's. but oh well, the kings do have their place for some of the rougher stuff..... i duno, just kind of thought it would have smoothed out all the imperfections of the southern california freeways. instead i feel all of it.
  4. Nov 6, 2017 at 3:28 PM
    Drtnap19
    Drtnap19 Well-Known Member
    Bluegrass
    2011 DC Tacoma 4x4
    That is one fine looking ride!
  5. Nov 6, 2017 at 3:48 PM
    eon_blue
    Azusa, CA
    I have the headstrong 3 leaf AAL (same as the icon 3 leaf) and its stiff as hell. Was better when I put my rear Icons w/resis back there but I don't think it'll get much better until I swap out the AALs for aftermarket leaf packs. I have a 1st gen though with a lighter back end so maybe that has something to do with it.
  6. Nov 6, 2017 at 5:50 PM
    hoverlover
    hoverlover Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    The above posts should get you heading in the right direction to soften up your ride.
    Changing out those leafs will really make a difference in the front. After I put the Kings up from I had to wait a couple weeks to install the rears. Once I did it made a huge difference in how the whole truck felt. I couldn't believe how much it changed for the better.
    Taking out a bit of preload should also help out. Adding weight should soften them up as well.
    If all else falls, send them in to Down South Motorsports for a revalve. Let them know what you want and they'll make it happen.
    (For reference, I have extended travel Kings with 700lb coils and 8 threads showing above the adjustment rings (about 2" between the ring and the bottom of the hat) and Dakars, ride is plush.)
    BassAckwards likes this.
  7. Nov 6, 2017 at 6:37 PM
    jnmargarit
    jnmargarit Well-Known Member
    Vancouver, B.C.
    '14 TRD Sport
    From your picture OP, it looks like there is too much preload on those coilovers. How much lift do you have them cranked too?
  8. Nov 6, 2017 at 7:07 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    OK, flame way guys but I have a 2014 TRD Off Road. I LOVED the factory ride and didn't want it to change.
    I put in a spacer lift and couldn't be happier with it. I do some off road driving with it, mostly fields and field roads around here. It's been flawless since the install.
    For any other of you cheap bastards out there considering a spacer lift, I wouldn't go more than 2".
    I did have to install the ECGS bushing on my driver side afterward to get rid of the droning vibration.
    Your mileage may vary.
  9. Nov 6, 2017 at 7:11 PM
    eon_blue
    Azusa, CA
    No flaming here, but anyone considering spacers should know that they compromise the integrity of the shocks they're mounted on and will cause the shocks to wear prematurely at best, at worst they can break the shock and cause a dangerous scenario.
    Not saying they aren't an effective way to lift on the cheap, but there are risks involved. If you plan on wheeling regularly you might want to be especially careful.
    Coot83 and EatSleepTacos like this.
  10. Nov 6, 2017 at 7:43 PM
    winkel
    Corydon, IN
    I did install the Toytech shock extenders to the rears and drop limit straps on the front. My passenger side UCA was hitting the coil spring on full extension. I also extended the front bump stops.
    I'll keep an eye on things but I didn't want a stiffer ride so the spacer provided a little lift without compromising that. We have a small bridge near us that I jump a couple of times a week so I am being kind of hard on it in that respect. If I damage a front strut, I'll report back and eat crow.
  11. Nov 6, 2017 at 7:46 PM
    eon_blue
    Azusa, CA
    :eek: Jumping your truck even with coilovers is a recipe for broken suspension, trashed ball joints, tweaked frames, etc...you need long travel dude, lol.
    Coot83 and jnmargarit like this.
  12. Nov 6, 2017 at 7:47 PM
    winkel
    Corydon, IN
    I don't mean to sound like a dick here but can you point me to a thread or discussion where someone had a problem with a moderate spacer lift. I'm not arguing the point, just really curious if I'm in for future problems. I did see on thread a while back that showed the bottom of a Biltein (yellow) strut that was bent pretty good but I don't remember the circumstances.
    Without the extended bump stops, I could see where this could be a problem.
  13. Nov 6, 2017 at 7:49 PM
    eon_blue
    Azusa, CA
    There was a big thread on here maybe a month ago...milkteacoma or something like that....that snapped his shock with a spacer lift. I'll see if I can dig up the thread later when I'm not on my phone.
  14. Nov 6, 2017 at 7:52 PM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    Man that is a sweet looking truck
  15. Nov 6, 2017 at 8:00 PM
    #35
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    My regular old 5100/eibach and wheelers 6 leaf is quite stiff.
    I drove on a washboard road not even going 20 and was getting beat to death. Things were flexing and shaking in ways I didn't know were possible, I swore the steering column was gonna fall off. Interested in how to make it soft again
  16. Nov 6, 2017 at 8:53 PM
    #36
    eon_blue
    Azusa, CA
    What are the Eibachs rated at weight wise? Are the 5100s set to 0 or..?
  17. Nov 7, 2017 at 5:38 AM
    #37
    taco terror
    USA
    Set at zero and they are 620lb coils
    It is nice on smooth roads because I don't really have body roll, but you can feel it over rough pavement.
  18. Nov 7, 2017 at 5:42 AM
    #38
    Flyinbrianbmx
    Flyinbrianbmx Well-Known Member
    2016 Blue Tacoma SR5 Rockstar
    look badass though
  19. Nov 7, 2017 at 5:42 AM
    #39
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    This right here. The add a leaf is only for height and not for performance. The add a leafs also sag eventually over time. I have 600 weight kings in the front that just eat up stuff and the rear has adjusters. I too would bet a good leaf pack would cure your rear pretty fast. Good thing you got kings instead of icons if you think your suspension is too stiff.
  20. Nov 7, 2017 at 5:43 AM
    #40
    Coot83
    Scottsdale, Az
    2012 Baja TX
    This can help if you add some weight like some quality skids underneath or a front bumper as the weight will soften them up front a bit more.
