Stiff ride
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nailer28, Jan 7, 2010.
  1. Jan 7, 2010 at 1:05 PM
    Nailer28
    Nailer28 [OP] Well-Known Member
    New Hampshire
    05 tacoma
    Billet Grill Dual flowmaster K/n
    Little help guys did a 3 inch lift in june and found that the ride quility is wicked stiff i used 885 coils and 5100s all the way around if i went to an 884 coil would that help the ride and still give me the same lift thanks to all
  2. Jan 7, 2010 at 1:07 PM
    jodiddly33
    jodiddly33 Well-Known Member
    Jonah
    DFW
    2010 Golf TDI
    If you have a DC then I'm pretty sure the 885s are recommended so I don't know :-/
  3. Jan 7, 2010 at 1:09 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    You can try the 884s....Lift might not be quite as much.
    For the DC...885s are the recommended. I'd try the OME shocks over the 5100s if it were me....They are built to go together.
  4. Jan 7, 2010 at 1:23 PM
    09Doright8126
    09Doright8126 Well-Known Member
    Andrew
    Greenwood, SC
    '09 DC TRD Offroad Pyrite Prerunner
    Aires chrome bullbar, Wet Okole seat covers, 6" KC offroad Slimlites w/ covers, upper Grillecraft black w/ TRD emblem, Redline hood struts, URD TCAI w/ black wrap, URD MAF Sensor, NST pulleys, NST intake manifold spacer, Bilstein 5100s, Eibach coils painted red, painted red brake calipers, SST brake lines, debadged tailgate, window tint, bed mat, extra D-rings, Rear TSB, Tranny TSB, swaybar removed, DTLT headers, URD Y-pipe, Vibrant Resonator, MagnaFlow
    That's what she said!! Sorry, had to do it...
    I have the 5100s w/ Eibach coils set at stock giving me 1.6" lift up front and notice that the ride is a bit more stiff than stock but I like the confidence of knowing I have a beefier setup over stock.
  5. Jan 7, 2010 at 4:41 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    885's should only be installed with OME Nitro shocks. 884's can get away with 5100's.
    You didn't set the 5100's to any other setting but zero right?
  6. Jan 7, 2010 at 4:48 PM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    I have the same except for the shocks. I can not handle the ride anymore... so last week I ordered the toytec complete lift - 885 coils, ome shocks all around and rear OME springs with U bolts & bushings. hopefully the ride will change for the better a little, not to mention i might actually be able to put some weight in the back now :D
    as soon as i get it in a take a little ride around town I will let you know.
  7. Jan 7, 2010 at 5:03 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    I have 885 and 5100 and the ride is fine...
  8. Jan 7, 2010 at 5:04 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    oh and wrong...
  9. Jan 7, 2010 at 5:10 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    if you want a cadillac ride I recommend you go back to stock (or buy a cadillac) You could also get LT or something else, but pretty much any 3" suspenson lift is going to ride "stiff" compared to stock
