Stiff Steering - try this fix first
Discussion in '2nd Gen. Tacomas (2005-2015)' started by buck, Jul 19, 2010.
  1. Mar 10, 2023 at 10:38 AM
    #41
    Northeast87
    Northeast87 Member
    Tacoma TRD
    Spraying the ujoint on my steering shaft with pb blaster lube worked. Thanks!
  2. Apr 15, 2023 at 11:03 AM
    #42
    littleguydavid
    littleguydavid New Member
    David
    1995 tacoma 2.4l
    Base and stock
    Was having same problem. Being unsure of the problem I was considering pump replacement. Sprayed generously with Deep Creep. Problem resolved. Thanks for taking the time and the effort to everyone that contributed to this post. I got my 95 in 2017 from a guy in Illinois that relocated from Las Vegas so truck isn't all rusted out. Has 301,000 miles and still runs good. A little sunburned but I just primered the hood and fenders and put some undercoating on the underside. Should serve me for several years. Will get under it again this summer and rust paint any visible rusty areas spots. I sure hate Illinois road salt!!!
  3. Sep 11, 2023 at 2:56 PM
    #43
    WebberLander
    WebberLander Well-Known Member
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    THANK YOU for this thread. Lubing it up worked. Replacing it was worth it in the long run. The U-joint was worn out. I'm getting close to 293,000 miles FWIW.
  4. Sep 22, 2023 at 11:12 AM
    #44
    tacomapersona
    tacomapersona New Member
    DCSB TRD OR ‘08
    Thank you, fixed my steering stiffness with deep creep. Wish I would have seen this before replacing the ps pump but hey got a new ps pump now too
  5. Mar 16, 2024 at 7:32 AM
    #45
    BarrieTaco
    BarrieTaco New Member
    Sprayed with lithium grease a few times which worked but ended up getting it repaired.
    When I got it back from the shop, I found the steering wheel is off a few degrees; when tracking straight down the road the steering wheel is a few degrees to the left.
    Is it reasonable to ask the shop to straighten it out or should I leave it and just get used to it?
    I find it annoying but the performance is fine and it drives safely.
  6. Apr 1, 2024 at 7:01 AM
    #46
    astonb86
    astonb86 Well-Known Member
    Aston
    2011 Tacoma TRD Off-Road
    Its surprising how easy this issue is to fix. I recently replaced my rack and pinion and thought the stiff steering was possibly from this. I was a bit confused when it the issue remained after the replacement. I did however climb under the truck and first clean the U joint with a penetrating lube the added lubricant. Night and day difference.
  7. Jul 31, 2024 at 7:19 AM
    #47
    mooch91
    mooch91 Well-Known Member
    PA
    2012 Tacoma AC SR5 4x4
    Old post I know, but YES it's more than reasonable, it's an expectation that they put it back straight. This is caused by a misalignment of the shaft to either the steering wheel or the rack when reassembling. They likely didn't mark its position before taking the old one off.
  8. Jul 31, 2024 at 7:21 AM
    #48
    mooch91
    PA
    Anyone who has lubricated the intermediate shaft, have you had better success with one lubricant over another? I had initially used PB Blaster followed by some white lithium grease, but I found it didn't really do much. The spray lithium grease seemed to dry up quickly. I repeated by cleaning the joint well with degreaser and then using a silicone based lube which appears to be working for now. Thanks!
  9. Jul 31, 2024 at 9:04 AM
    #49
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Just replace it
    Lubing it repeatedly is just a bandaid.
  10. Jul 31, 2024 at 2:56 PM
    #50
    slossboss
    slossboss Well-Known Member
    Troy
    FL
    2013 TRD Sport 4x4 Nautical Blue Metallic
    I’m not sure what kind of voodoo is on this post, but I happened to skim this today. A few hours later, sure enough, I make a left turn and it’s stiff and then smooth just like how OP described.
