Stiff Steering While Engaged in 4wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ogsambal, Jun 3, 2019.
  1. Jun 3, 2019 at 9:28 AM
    ogsambal
    ogsambal [OP] Well-Known Member
    Ohio
    2014 Toyota Tacoma- 3” lift 33’s 2003 Lexus RX300 2001 Toyota Tacoma
    Word. Thanks for the input dude!
    eon_blue[QUOTED] likes this.
  2. Jun 3, 2019 at 9:32 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I've never felt my steering to be any tighter in 4wd unless I'm turning on a surface that has more traction and the drivetrain is fighting back against the steering (it happens sometimes...come across a solid rock platform offroad with a lot of traction or forget to turn 4wd off once the trail is over).
    What you're describing sounds like drivetrain bind up to me but if it's happening at all times in 4wd it might be something different. Afraid I'm not sure what else it could be
  3. Jun 3, 2019 at 10:07 AM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    Have only used 4x4 in the snow so that I’m sure would mask any stiffness in 4x4. Mine got the intermediate shaft problem at around 80k. The symptom for me was the steering didn’t return to center after turning a corner. Replaced the shaft and been trouble free since. At 168k now.
    ogsambal[OP] likes this.
  4. Jul 2, 2022 at 5:34 PM
    optifree
    optifree Well-Known Member
    Gary
    Pflugerville
    2010 AC TRD
    OME
    Can you drive with 2wdH on wet roads though, including maybe making some turns?
  5. Jul 2, 2022 at 6:06 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    FIFY
    Sweeping turns are ok. Parking lot turns not so much. You will feel the steering bind up. The wheels also may skip/chirp. Don’t do that.
    SR-71A likes this.
  6. Jul 2, 2022 at 9:36 PM
    optifree
    Gary
    Pflugerville
    2010 AC TRD
    OME
    Oh yeah, I know you should not make tight turns using it. I was thinking if it rains and I need the extra traction, if I can drive with it in 4wd on wet roads. I had a Silverado that when it rained I would put the dial in Auto mode, when rear wheels slipped the fronts would engage.
  7. Jul 2, 2022 at 9:42 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Wet pavement still isn't slippery enough to safely use 4wd. If you lack grip in 2wd maybe consider changing tires or driving habits. Also some weight in the bed can help
    SR-71A likes this.
  8. Jul 2, 2022 at 9:46 PM
    saint277
    saint277 Vigilo Confido
    Oh sweet Jesus I've seen way to many of these sharp turns in 4x4 threads on here
  9. Jul 3, 2022 at 5:19 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The Silverado had a different system.
    The 4X4 system used in Tacoma is an old school "dumb" system that isn't really any different than what was used 100 years ago. When engaged the front and rear axles are locked together and it tries to force all 4 wheels to turn at the same speed. It is a simple, inexpensive system that is still the best system for hard-core off-road driving where traction is poor. Or on pavement in limited situations.
    When cornering the inside wheels have less distance to travel, but since they are turning at the same speed they need to slip slightly on the ground. Especially the front inside wheel when moving forward or the rear inside wheel when in reverse. If traction is too good to allow some slip you can break drive line components. Even slight turns puts excessive wear on components. They may not fail immediately, but continued use will lead to premature parts failure.
    Some newer systems use data from wheel speed sensors to send power to all 4 wheels, yet let them turn at varying speeds. That is what your Silverado had. This is similar to All Wheel Drive like Subaru and many other small SUV's use. That system works great on wet pavement, light snow, or mild offroad conditions. But in harsh offroad conditions or deep snow where traction is really poor it isn't as good as the old school 4X4. These systems cost a lot more too.
    Back in the 1970's when I 1st started driving 4X4's everyone knew how and when to engage 4x4 and no one had these issues. But by the late 70's some of the newer AWD, and Full Time 4X4 systems started to be put on vehicles. Lots of folks today don't understand the difference. Some can be used on pavement, some cannot. Tacoma cannot.
  10. Jul 3, 2022 at 5:43 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Turning isn't allowed. Whenever I'm at an intersection I wait for another Tacoma to approach in the direction I want to go, and we trade vehicles.
    Yesterday was a challenge because i traded with a guy leaving the store I wanted to go towards, so I had to drive backwards for about a mile. But at least that truck had hated seats, so that was nice.
    UnloadedRex likes this.
