stiff steering
Discussion in '1st Gen. Tacomas (1995-2004)' started by cdm97, Nov 27, 2017.
  1. Nov 27, 2017 at 12:09 PM
    cdm97
    cdm97 [OP] Active Member
    2000 Tacoma TRD
    Custom Interior, Aftermarket Audio, leveled (32/11.5 BFG AT's, Method Standards), Performance Intake
    Hey all,
    So my truck is getting noticeably harder to turn. What I find strange is that on the last turn of the wheel its almost like it will "give" and then the last full rotation feels really easy. Maybe some binding, maybe the power steering pump or even the rack and pinion. Anyone else have the same problem?
    wilcam47 likes this.
  2. Nov 27, 2017 at 2:57 PM
    Glamisman
    Glamisman Well-Known Member
    crawl under her and look at the steering rack where the large nut/socket is, on the D/S, you will see it. If yours has the large nut it has the old stlye rack guide... it is litterly two pieces of metal rubbing. This is one possibility.
    If it is a socket/depression type, it is updated and has a roller, it is the best you can get. You will need to look elsewhere for the problem.
  3. Nov 27, 2017 at 3:57 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    You have that backwards, in concept and application.
  4. Nov 27, 2017 at 4:00 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    mi
    mine does that when the powersteering is low on fluid...I have a small leak which eventually I have to fix but its ok for now. Once I fill it up I have to cycle the steering from left to right to get air out of the system.
  5. Nov 27, 2017 at 4:09 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Yeah, I'd check your PS fluid level first, it might be low. If it is, re-fill it and then look for leaks. I don't generally hear of our PS pumps going bad too often, but that's always a possibility I guess.
    The other thing to do is jack up the front end (both wheels, support frame with jackstands) and see if you still feel resistance, then get under there while a buddy steers it back and forth and see if you can see/hear any problem spots. Just start at one side and look at/listen to everything you see moving. Look for oil/grease collecting on or near the steering rack.
    While you're there, might as well check your ball joints and tie rod ends too.
  6. Nov 27, 2017 at 8:16 PM
    Glamisman
    I stand corrected...
  7. Nov 28, 2017 at 11:20 AM
    cdm97
    2000 Tacoma TRD
    Thanks for the responses! I just replaced my ball joints but I do need to find the time to throw in new tie rods (which I have). The power steerring fluid reservoir is full as of Sunday (26 Nov 17). I always start with most likely to least likely problems which is why I ended up throwing this post out here. Would the rack and pinion have any effect on this?
  8. Dec 22, 2017 at 7:47 AM
    coveylane
    coveylane Well-Known Member
    Coveylane
    Nova Scotia
    08 Tacoma SR5 4x4
    Spray some Lube or Penetrating fluid on the little universal on the steering shaft and see if that helps it. They all stiffen up on the 2nd gen Tacomas and eventually have to be replaced.
